HDFSConnector
                                            Accesses an HDFS (Hadoop Distributed File System) to upload, download, or delete files and folders; or list the contents of a folder from an HDFS service.
- Manage datasets on HDFS by uploading, downloading, and deleting files and folders
 - Transfer a file's contents (such as XML, point cloud, or raster) into or out of an attribute in FME
 - Read downloaded HDFS data using the FeatureReader, or upload data written by the FeatureWriter to HDFS
 - Retrieve file and folder names, paths, links and other information from HDFS to use elsewhere in a workspace.
The HDFSConnector uses your HDFS account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, path attributes are added to the output features. On List actions, file/folder information is added as attributes.
- This transformer cannot be used to directly move or copy files between different HDFS locations. However, multiple HDFSConnectors can be used to accomplish these tasks.
 - The FeatureReader can access HDFS directly (without using the HDFSConnector), however, a local copy of the dataset will not be created.
The output of this transformer will vary depending on the HDFS Action performed.
- After an Upload action, the HDFS path and ID of the file will be saved to an attribute.
 - A Download action can save to a file, a folder, or an attribute.
 - A Delete action has no output ports.
 - A List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
        HDFS Action  |
        The type of operation to perform. Choices include:
        HDFS Account  |
        Performing operations against an HDFS account requires the use of 1 of the 3 available authentication mechanisms (Simple, Token, Kerberos) using a Web Connection. To create an HDFS connection, click the HDFS Account drop-down box and select Add Web Connection. The connection can then be managed via Tools > FME Options > Web Connections.  |
The remaining parameters available depend on the value of the Request > HDFS Action parameter. Parameters for each HDFS Action are detailed below.
HDFS Path
        Path to Delete  |
        The path of a file or folder on HDFS to delete. If valid credentials have been provided as a web connection, you may browse to a location.  |
HDFS Source
        Download from Path  |
        The HDFS path of the file/folder to download. If valid credentials have been provided as a web connection, you may browse to a location.  |
Destination
        Download as  |
        Select whether to store the downloaded data in a File, Folder, or Attribute.
        Download to Folder  |
        Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder.  |
        Include Subfolders  |
        Choose whether to download subfolders of the HDFS Source or not. Valid for Download as Folder only.  |
        Download to Attribute  |
        Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only. Note  FME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as File instead.
HDFS Path
        List Contents at Path  |
        The folder path on HDFS to list the contents of. If valid credentials have been provided as a web connection, you may browse to a location.  |
Output Attributes
        Attributes to Add  |
        The selected attributes will be added to the output feature.
Source
        Upload  |
        The type of data to be uploaded.
 When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. HDFS treats file uploads of the same name, in a specific folder, as duplicates, so you can upload multiple files with the same name to a specific folder. When wanting to upload content from a folder, it is better to upload as a folder instead of setting a fixed path and sending multiple features into the connector to upload as a file.  |
        File to Upload  |
        The file to be uploaded to HDFS if Upload is set to File.  |
        Folder to Upload  |
        The folder to be uploaded to HDFS if Upload is set to Folder.  |
        Choose whether to upload subfolders of the Folder to Upload or not.  |
        Attribute to Upload as File  |
        The data to be uploaded, supplied from an attribute if Upload is set to Attribute.  |
HDFS Destination
        Upload to Path  |
        The path on HDFS to upload the source file to. To upload to the root directory, enter “/”.  |
        Upload with File Name  |
        The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc).  |
Upload Options
        If File Exists at Destination  |
        Choose whether to overwrite, append, or do nothing if a file exists at the upload destination.  |
        File/Directory Permission  |
        The octal permission (UNIX format) value to set for the uploaded object. This parameter is unavailable if “Append” is chosen for the previous parameter. The object will retain its original permission setting in this case.  |
Output Attributes
        Attributes to Add  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
| Dependencies | HDFS account |
| History | Released FME 2018.0 |
Search for all results about the HDFSConnector on the FME Community.
