CesiumIonConnector
                                            Uploads a folder dataset to the Cesium ion service as a new asset.
The CesiumIonConnector uses your Cesium ion account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the service.
A folder containing one of :
- A CityGML file and a textures subdirectory
 - GeoTIFF files
 - LAS files
 - OBJ files
is supported for upload.
Features that have successfully uploaded the specified folder to Cesium ion are output through this port.
The feature will have the following attributes added on to it that represent information about the request to Cesium ion and the created asset.
        _cesiumion_url  |
        The URL of the new asset  |
        _cesiumion_id  |
        Numerical ID of the new asset  |
        _cesiumion_user_id  |
        ID of the user account |
        _cesiumion_type  |
        The type of asset. One of 3DTILES, IMAGERY, or TERRAIN.  |
        _cesiumion_name  |
        The name of the new asset  |
        _cesiumion_description  |
        The description for the new asset  |
        _cesiumion_bytes  |
        Number of bytes uploaded  |
        _cesiumion_date_added  |
        Date the asset was added  |
        _cesiumion_status  |
        Cesium ion processing status. One of NOT_STARTED, IN_PROGRESS, COMPLETE or ERROR  |
        _cesiumion_percent_complete  |
        Processing percent complete  |
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
        Cesium ion Account  |
        To create a Cesium ion connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections.  |
        Action  |
        The type of operation to perform. Choices include:
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Options
        Asset ID  |
        The Cesium ion asset to delete.  |
Options
        Source Folder  |
        The path to the folder to upload as an asset. The folder should contain one of :
        Asset Name  |
        The name to give the new asset on Cesium ion.  |
        Asset Description  |
        The description to give the new asset on Cesium ion.  |
Wait Behavior
        Wait for ion Processing  |
        If this option is set to Yes, FME will wait for Cesium ion to finish processing the uploaded asset.  |
        Processing Timeout (s)  |
        The maximum amount of time, in seconds, to wait for Cesium ion asset processing to complete. The translation will still succeed if the timeout is reached, but the uploaded asset is not guaranteed to be ready for use.  |
Manual Georeferencing
If checked, specify a latitude, longitude and height in order to georeference an unreferenced OBJ file. Has no effect on other formats.
        Latitude (Degrees)  |
        The latitude for the coordinates of the georeference.  |
        Longitude (Degrees)  |
        The longitude for the coordinates of the georeference.  |
        Height (Meters)  |
        The height for the coordinates of the georeference.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
| Dependencies | Cesium ion Account |
| History | Released FME 2019.0 |
Search for all results about the CesiumIonConnector on the FME Community.
