S3Connector
                                            Accesses the Amazon Simple Storage Service (S3) file storage service to upload, download, or delete files and folders or list file/folder information from an S3 account.
- Manage datasets on S3 by uploading, downloading, and deleting files and folders
 - Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
 - Read downloaded S3 data using the FeatureReader, or upload data written by the FeatureWriter to S3
 - Retrieve file and folder names, paths, links and other information from S3 to use elsewhere in a workspace.
The S3Connector uses your Amazon S3 account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, link attributes can be added to the output features. On List actions, file/folder information are added as attributes.
- This transformer cannot be used to directly move or copy files between different S3 locations. However, multiple S3Connectors can be used to move or copy files with an intermediate download.
 - The FeatureReader can access S3 directly, without using the S3Connector. In this case, a local copy of the dataset will not be created.
The output of this transformer will vary depending on the S3 Action performed.
- After an Upload action, URLs to the file may be saved to the Direct Link attribute, and the bucket and path to the object will saved to the Full Path attribute.
 - A Download action will output a new feature and can save to either a file, folder or attribute.
 - A Delete action will output a new feature.
 - A List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
        Credential Source  |
        The S3Connector can use credentials from different sources. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
        Account  |
        Available when the credential source is Web Connection. To create an S3 connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections.  |
        Region
        The AWS Region in which the specified Bucket resides. If the default value, US East, N. Virginia (us-east-1), is specified, and the specified Bucket does not reside there, the operation will still succeed. However, to optimize latency, it is best practice to specify the correct region. |
        Alternate Endpoint  |
        If specified, use an alternate S3-compatible API. These are typically object storage services from providers other than AWS, or on-premises solutions.  |
        Verify HTTPS Certificates  |
        AWS CA Bundle  |
        The AWS CA Bundle specifies the path to a certificate bundle to use for certificate validation. If set, this has precedence over the value of the AWS_CA_BUNDLE environment variable.  |
        Requester Pays  |
        Some public buckets require the requester to pay the cost of operations performed. Setting this parameter to Yes will allow AWS to charge the account associated with the provided credentials to be charged.  |
        Access Key ID and Secret Access Key  |
        Available when the credential source is Embedded. An access key ID and secret access key can be specified directly in the transformer instead of in a web connection.  |
        Session Token  |
        Optional. Available when the credential source is Embedded. If specified, use the temporary security credentials to connect to S3.  |
        Action  |
        The type of operation to perform. Choices are:
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Delete Options
        Bucket  |
        The bucket the file or folder is in. If valid credentials have been provided as a web connection, you may browse for a bucket.  |
        Path  |
        The full path of a file or folder on S3 to delete. If valid credentials have been provided as a web connection, you may browse for a location.  |
Download Options
        Bucket  |
        Path  |
        The full path of a file or folder on S3 to download. If valid credentials have been provided as a web connection, you may browse for a location.  |
        S3 Acceleration  |
        If Yes, allows Amazon S3 Transfer Acceleration on the bucket, if enabled. To enable acceleration, see https://docs.aws.amazon.com/AmazonS3/latest/UG/enable-bucket-transfer-acceleration.html. When allowing S3 Acceleration, keep in mind the following:
Destination
        Download as  |
        Select whether to store the downloaded data in a File, Folder or Attribute.
        Download to Attribute  |
        Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only.  |
        Response Body Encoding  |
        For Download as Attribute, you can specify a character set encoding to ensure the output is in a human-readable form. If Auto Detect from HTTP Header is specified but there is no encoding in the Content-Type metadata associated with the data, the output will be returned as raw bytes.  |
        Download to Folder  |
        Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder.  |
        If File Exists  |
        Specify what to do if the file already exists locally. Valid for Download as File or Folder.
        Include Subfolders  |
        Choose whether to download subfolders of the S3 Source or not. Valid for Download as Folder only. Default: No.  |
Output Attributes
        Attributes to Add  |
        The selected attributes will be added to the output feature.
List Options
        Bucket  |
        The bucket the folder is in. If valid credentials have been provided as a web connection, you may browse for a bucket.  |
        Path  |
        The full path to the folder on S3 to list. If valid credentials have been provided as a web connection, you may browse for a location.  |
        If set to Yes, then subfolders are recursively traversed, and their contents are included in the result. Default: No.  |
Output Attributes
        Attributes to Add  |
Data Source
        Upload  |
        The type of data to be uploaded.
 When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. S3 treats file uploads of the same name, in a specific folder, as duplicates, but does not allow multiple instances in a specific folder. You must upload the file to a different folder than the existing one or the original will be overwritten. When wanting to upload content from a folder, it is better to upload as a folder instead of setting a fixed path and sending multiple features into the connector to upload as a file.  |
        File to Upload  |
        The file to be uploaded to S3 if Upload is set to File.  |
        Folder to Upload  |
        The folder to be uploaded to S3 if Upload is set to Folder.  |
        Choose whether or not to upload subfolders of the Folder to Upload.  |
        Contents Only  |
        Attribute to Upload as File  |
        The data to be uploaded, supplied from an attribute if Upload is set to Attribute.  |
Upload Options
        Bucket  |
        Path  |
        The full path to the folder on S3 to upload to. If valid credentials have been provided as a web connection, you may browse for a location.  |
        Upload with File Name  |
        The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc).  |
        If File Exists  |
        Specify what to do if the file already exists on S3.
        S3 Acceleration  |
        Encryption  |
        Permissions  |
        The predefined set of grantees and permissions to store with each uploaded object. For more information, see https://docs.aws.amazon.com/AmazonS3/latest/dev/ACLOverview.html#CannedACL.  |
        Generate Presigned URL  |
        If enabled, a presigned URL is generated for the uploaded file, and stored in the _presigned_url attribute. This allows access to the file without credentials for the bucket. For more information, see https://docs.aws.amazon.com/AmazonS3/latest/dev/ShareObjectPreSignedURL.html.  |
        Expiry  |
        When generating a presigned URL, optionally specify a number of seconds for which the link will remain valid.  |
        Metadata  |
        You can specify header fields in the HTTP upload request. Under Name, specify a header field. You can select from a drop-down list of predefined fields that include metadata and ACL permissions parameters. Alternatively, enter fields manually. Under Value, specify a field value. Custom metadata fields will automatically be prefixed with ‘x-amz-meta-’ by AWS.  |
Output Attributes
        Attributes to Add  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
| Dependencies | S3 account |
| Aliases | S3Deleter, S3Downloader, S3ObjectLister, S3Uploader |
| History | Released FME 2019.0 |
Search for all results about the S3Connector on the FME Community.
