PointCloudThinner
Reduces the number of points in (thins) a point cloud by keeping points at a fixed interval, a maximum number of points, or a set quantity of first or last points. Remaining points are discarded.
- Reducing the data volume of a point cloud feature to meet processing or storage requirements.
 - Creating a sample point cloud dataset for testing
The PointCloudThinner receives point cloud features and outputs them with fewer points than the original.
The Points to Keep are identified by a fixed interval, a maximum number of points, or by specifying a first or last number of points:
| Thinning Type | Amount | Result |
                                                             Every Nth Point (Interval)  |
                                                             5  |
                                                             Every 5th point of the input cloud feature will be present in the output point cloud.  |
                                                             Every Nth Point (Maximum Number of Points)  |
                                                             100  |
                                                             The output cloud will have a maximum of 100 points, evenly spaced throughout the input.  |
                                                             First N Points  |
                                                             100  |
                                                             The first 100 points from the input will be kept.  |
                                                             Last N Points  |
                                                             500  |
                                                             The last 500 points from the input will be kept.  |
In this example, we will reduce the number of points in a point cloud. Note that the original dataset has over 23 million points.
The point cloud feature is routed into a PointCloudThinner.
In the parameters dialog, Points to Keep is set to Every Nth point (Interval), and the Interval is set to 500.
Every 500th point has been retained, and all other points discarded. The output feature has only 46,110 points.
- For finer control over how a point cloud is reduced, consider using the PointCloudSimplifier transformer. It reduces while maintaining the overall shape of the original point cloud feature, however, may take considerably more processing time.
        Combines features into a single point cloud. Point cloud and non-point cloud geometries are supported.  |
        Adds new components with constant values to a point cloud.  |
        Copies selected component values onto either a new or existing component  |
        Keeps only specified point cloud components, discarding all others.  |
        Removes specified components from a point cloud.  |
        Renames an existing component.  |
        Alters the data type of point cloud components, and converts component values if required.  |
        Reads point cloud features for testing purposes, including any accumulated point cloud operations. No additional operations are performed, and nothing is done with the features.  |
        Creates a point cloud of specified size and density, with default component values.  |
        Evaluates expressions on each point in a point cloud feature, including algebraic operations and conditional statements, and sets individual point cloud component values.  |
        Serializes the geometry of a point cloud feature into a Blob attribute, encoding the contents according to a choice of common binary point cloud formats.  |
        Separates point clouds into multiple features, based on evaluating expressions including component values, and creates a separate output port for each expression defined.  |
        Merges point clouds by joining points where selected component values match (join key), including x, y, z, and other components. Component values are transferred between point clouds and output is filtered based on matching success and duplication.  |
        Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location.  |
        Extracts the geometry properties of a point cloud feature and exposes them as attributes, optionally checking for their existence, retrieving component properties, and finding minimum and maximum values. Extents may also be recalculated and updated.  |
        Decodes a binary attribute containing encoded point clouds stored as Blobs, replacing the feature’s geometry with the decoded point cloud.  |
        Reduces the number of points in a point cloud by selectively keeping points based on the shape of the point cloud. The simplified and removed points are output as two discrete point clouds.  |
        Sorts the points within a point cloud by one or more component values.  |
        Separates point clouds into multiple features based on component values, color, or first/last return.  |
        Calculates statistics on point cloud components and adds the results as attributes.  |
        Takes an input point cloud and reconstructs it into an output mesh.  |
        Reduces the number of points in (thins) a point cloud by keeping points at a fixed interval, a maximum number of points, or a set quantity of first or last points. Remaining points are discarded.  |
        Converts point clouds to point or multipoint geometries, optionally retaining attribute and component values.  |
        Applies a point cloud’s scale, offset, or transformation matrix to it, recalculating component values and removing the transformation values.  |
Point cloud features with a reduced number of points as specified.
        Points to Keep  |
        Select the method for identifying points to keep. Options include:
        Interval  |
        When Points to Keep is Every Nth Point (Interval), specify how often the points are retained. For example, an Interval of 10 will result in every tenth point of the input cloud feature being kept in the output point cloud.  |
        Maximum Number of Points  |
        When Points to Keep is Every Nth Point (Maximum Number of Points) or First/Last N Points, specify the maximum points in the output point cloud. This value may be set explicitly or defined with an attribute value or an expression.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
| Aliases | PointCloudSampler |
Search for all results about the PointCloudThinner on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
