PointCloudComponentCopier
                                            Copies selected component values onto either a new or existing component.
- Creating copies of components and their values to meet processing requirements
 - Creating backup copies of values before manipulating them
The PointCloudComponentCopier receives point cloud features, copies specified components and their values onto new or existing components, then outputs the modified point cloud feature.
The Source Component remains intact, and the Target Component will be created (if new) or have its values overwritten (if existing).
Multiple components may be copied.
In this example, we want to create backup copies of the x, y, and z component values in a point cloud before performing manipulations on them.
Note that the source point cloud has x, y, and z components.
The point cloud is routed into a PointCloudComponentCopier.
In the parameters dialog, we make three entries in the Components to Copy table - one for each of x, y, and z. New component names are assigned in the Target Component column, which will be added as new components.
The output point cloud feature has three new components, containing a copy of the original components’ values, and is passed on into the workspace for further processing.
If desired, another PointCloudComponentCopier could be used after x,y, and z are manipulated - copying from the new orig_x, orig_y, and orig_z back onto x, y, and z - to restore the original values.
- To create or update components with values more complex than simply copying, consider using the PointCloudExpressionEvaluator.
 - To add a new component with a constant value, use the PointCloudComponentAdder.
 - To copy values from a raster onto point cloud components, use the PointCloudOnRasterComponentSetter.
 - To change the name of a component while retaining its values (elevation to z, for example), use the PointCloudComponentRenamer.
        Combines features into a single point cloud. Point cloud and non-point cloud geometries are supported.  |
        Adds new components with constant values to a point cloud.  |
        Copies selected component values onto either a new or existing component  |
        Keeps only specified point cloud components, discarding all others.  |
        Removes specified components from a point cloud.  |
        Renames an existing component.  |
        Alters the data type of point cloud components, and converts component values if required.  |
        Reads point cloud features for testing purposes, including any accumulated point cloud operations. No additional operations are performed, and nothing is done with the features.  |
        Creates a point cloud of specified size and density, with default component values.  |
        Evaluates expressions on each point in a point cloud feature, including algebraic operations and conditional statements, and sets individual point cloud component values.  |
        Serializes the geometry of a point cloud feature into a Blob attribute, encoding the contents according to a choice of common binary point cloud formats.  |
        Separates point clouds into multiple features, based on evaluating expressions including component values, and creates a separate output port for each expression defined.  |
        Merges point clouds by joining points where selected component values match (join key), including x, y, z, and other components. Component values are transferred between point clouds and output is filtered based on matching success and duplication.  |
        Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location.  |
        Extracts the geometry properties of a point cloud feature and exposes them as attributes, optionally checking for their existence, retrieving component properties, and finding minimum and maximum values. Extents may also be recalculated and updated.  |
        Decodes a binary attribute containing encoded point clouds stored as Blobs, replacing the feature’s geometry with the decoded point cloud.  |
        Reduces the number of points in a point cloud by selectively keeping points based on the shape of the point cloud. The simplified and removed points are output as two discrete point clouds.  |
        Sorts the points within a point cloud by one or more component values.  |
        Separates point clouds into multiple features based on component values, color, or first/last return.  |
        Calculates statistics on point cloud components and adds the results as attributes.  |
        Takes an input point cloud and reconstructs it into an output mesh.  |
        Reduces the number of points in (thins) a point cloud by keeping points at a fixed interval, a maximum number of points, or a set quantity of first or last points. Remaining points are discarded.  |
        Converts point clouds to point or multipoint geometries, optionally retaining attribute and component values.  |
        Applies a point cloud’s scale, offset, or transformation matrix to it, recalculating component values and removing the transformation values.  |
Point cloud features with components added or updated as specified in the parameters.
MISSING_FEATURE_COMPONENTS
Each line in this table specifies a component to be copied, and parameters for doing so. Multiple components may be modified.
        Source Component  |
        The source component to copy from.  |
        Target Component  |
        The target component to copy to. If this component already exists, its values will be overwritten.  |
Note that the drop-down menu for both Source and Target Component provides a list of standard component names. User-specified component names may be entered directly in both columns.
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
Search for all results about the PointCloudComponentCopier on the FME Community.
