PointCloudComponentRenamer
                                            Renames an existing component.
- Renaming components to meet processing or format requirements.
The PointCloudComponentRenamer receives point cloud features, changes the names of selected existing components, and then outputs the modified point cloud feature.
Components may be renamed to standard component names or user-defined names. If a target component name (the new name) is already in use, that component will be overwritten.
Multiple components may be renamed at once.
In this example, we are starting with a text file (CSV) of cell signal measurements. We want to convert the entire dataset to a single point cloud.
Note that coordinates are available in the longitude and latitude attributes, however, the data is non-spatial at this point.
In order to treat the dataset as a point cloud and be able to perform spatial manipulations (such as reprojection), two steps are required.
First, the text records are routed into a PointCloudCombiner, where they are converted into a single point cloud feature.
Next, a PointCloudComponentRenamer is used to change the longitude and latitude values to x and y components - and so as individual point coordinates within the point cloud.
Step 1 - Conversion to Point Cloud
In the parameters dialog of the PointCloudCombiner, most of the input features’ attributes are kept by specifying them in the Attributes to Preserve as Components table. This will retain individual values on each point within the point cloud, including coordinates.
A single point cloud feature is output, but it does not yet have point geometries inside the point cloud. Note that the extents are nan, nan - meaning not a number.
Step 2 - Rename Coordinate Components
In the parameters dialog of the PointCloudComponentRenamer, we rename the longitude and latitude components to x and y - the standard coordinate component names.
Standard names are available on the Target Component’s drop-down menu.
The output point cloud feature now contains points and has valid extents.
The original CSV text file is now a point cloud, and may be passed along for further processing. Note that it does not have a z component, which could be created and set to zero (0) if necessary with a PointCloudComponentAdder.
- To duplicate a component and its values with a new name, use the PointCloudComponentCopier.
        Combines features into a single point cloud. Point cloud and non-point cloud geometries are supported.  |
        Adds new components with constant values to a point cloud.  |
        Copies selected component values onto either a new or existing component  |
        Keeps only specified point cloud components, discarding all others.  |
        Removes specified components from a point cloud.  |
        Renames an existing component.  |
        Alters the data type of point cloud components, and converts component values if required.  |
        Reads point cloud features for testing purposes, including any accumulated point cloud operations. No additional operations are performed, and nothing is done with the features.  |
        Creates a point cloud of specified size and density, with default component values.  |
        Evaluates expressions on each point in a point cloud feature, including algebraic operations and conditional statements, and sets individual point cloud component values.  |
        Serializes the geometry of a point cloud feature into a Blob attribute, encoding the contents according to a choice of common binary point cloud formats.  |
        Separates point clouds into multiple features, based on evaluating expressions including component values, and creates a separate output port for each expression defined.  |
        Merges point clouds by joining points where selected component values match (join key), including x, y, z, and other components. Component values are transferred between point clouds and output is filtered based on matching success and duplication.  |
        Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location.  |
        Extracts the geometry properties of a point cloud feature and exposes them as attributes, optionally checking for their existence, retrieving component properties, and finding minimum and maximum values. Extents may also be recalculated and updated.  |
        Decodes a binary attribute containing encoded point clouds stored as Blobs, replacing the feature’s geometry with the decoded point cloud.  |
        Reduces the number of points in a point cloud by selectively keeping points based on the shape of the point cloud. The simplified and removed points are output as two discrete point clouds.  |
        Sorts the points within a point cloud by one or more component values.  |
        Separates point clouds into multiple features based on component values, color, or first/last return.  |
        Calculates statistics on point cloud components and adds the results as attributes.  |
        Takes an input point cloud and reconstructs it into an output mesh.  |
        Reduces the number of points in (thins) a point cloud by keeping points at a fixed interval, a maximum number of points, or a set quantity of first or last points. Remaining points are discarded.  |
        Converts point clouds to point or multipoint geometries, optionally retaining attribute and component values.  |
        Applies a point cloud’s scale, offset, or transformation matrix to it, recalculating component values and removing the transformation values.  |
Point cloud features with component names altered as specified in the parameters.
MISSING_FEATURE_COMPONENTS
Each line in this table specifies a component to be renamed and its new name. Multiple components may be renamed.
        Source Component  |
        The source component name. Standard component names may be selected from the drop-down menu, whereas user-defined names are entered directly.  |
        Target Component  |
        The target component name. If this component already exists, it will be overwritten. Standard component names may be selected from the drop-down menu, whereas user-defined names are entered directly.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
Search for all results about the PointCloudComponentRenamer on the FME Community.
