PointCloudExtractor
Serializes the geometry of a point cloud feature into a Blob attribute, encoding the contents according to a choice of common binary point cloud formats.
- Storing point clouds in databases that do not support specific point cloud types but do support Blobs
Storage of point cloud geometry, as a temporary backup within a workspace
The PointCloudExtractor receives point cloud features and puts a copy of the point cloud geometry into an attribute, as a Blob - a Binary Large OBject.
The Blob content may be encoded as a variety of common point cloud formats. The name of the chosen format will also be recorded in an attribute for reference when decoding.
There are no parameters in the transformer to control how the point cloud is formatted, and encoding is done based on default settings for the chosen format. If necessary, format-specific settings may be overwritten by setting format attributes on the point cloud feature, prior to using the PointCloudExtractor. Consult the appropriate format’s Writer documentation for a complete list of available attributes and format limitations.
As the point cloud exits the transformer, it has two copies of its geometry - its original geometry and a copy as a Blob in an attribute.
In this example, we will prepare and write a point cloud to a PostgreSQL database, which does not support geometry as an attribute type.
The point cloud feature is routed into a PointCloudExtractor, and then on to a PostgreSQL Writer.
In the parameters dialog, Format is set to LAZ, and the Format Name and Blob attributes are left with the default names applied.
Examining the output from the PointCloudExtractor in the FME Data Inspector, note that the feature has two added attributes - _pointCloudBlob, containing the encoded point cloud, and _pointCloudFormatName, containing the name (LAZ) of the chosen encoding.
In the writer parameters, User Attributes, the Type of _pointCloudBlob is adjusted to bytea, which stores binary strings. (Note that the appropriate data type may vary between database formats.)
- When writing the point cloud Blob Attribute to a database, you may need to adjust the database User Attribute type to an unbounded data type to avoid truncation of the data. Choose an appropriate attribute type depending on the destination format.
 - The PointCloudReplacer may be used to perform the reverse operation and convert the encoded blob back to the original point cloud geometry.
 - To carry out a similar operation on vector data, use the GeometryExtractor transformer. For raster data, use the RasterExtractor.
 - To remove the original geometry after using a PointCloudExtractor (leaving only the Blob attribute version), use a GeometryRemover.
 - The AttributeFileWriter transformer can be used to write the point cloud Blob Attribute directly to a file.
        Combines features into a single point cloud. Point cloud and non-point cloud geometries are supported.  |
        Adds new components with constant values to a point cloud.  |
        Copies selected component values onto either a new or existing component  |
        Keeps only specified point cloud components, discarding all others.  |
        Removes specified components from a point cloud.  |
        Renames an existing component.  |
        Alters the data type of point cloud components, and converts component values if required.  |
        Reads point cloud features for testing purposes, including any accumulated point cloud operations. No additional operations are performed, and nothing is done with the features.  |
        Creates a point cloud of specified size and density, with default component values.  |
        Evaluates expressions on each point in a point cloud feature, including algebraic operations and conditional statements, and sets individual point cloud component values.  |
        Serializes the geometry of a point cloud feature into a Blob attribute, encoding the contents according to a choice of common binary point cloud formats.  |
        Separates point clouds into multiple features, based on evaluating expressions including component values, and creates a separate output port for each expression defined.  |
        Merges point clouds by joining points where selected component values match (join key), including x, y, z, and other components. Component values are transferred between point clouds and output is filtered based on matching success and duplication.  |
        Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location.  |
        Extracts the geometry properties of a point cloud feature and exposes them as attributes, optionally checking for their existence, retrieving component properties, and finding minimum and maximum values. Extents may also be recalculated and updated.  |
        Decodes a binary attribute containing encoded point clouds stored as Blobs, replacing the feature’s geometry with the decoded point cloud.  |
        Reduces the number of points in a point cloud by selectively keeping points based on the shape of the point cloud. The simplified and removed points are output as two discrete point clouds.  |
        Sorts the points within a point cloud by one or more component values.  |
        Separates point clouds into multiple features based on component values, color, or first/last return.  |
        Calculates statistics on point cloud components and adds the results as attributes.  |
        Takes an input point cloud and reconstructs it into an output mesh.  |
        Reduces the number of points in (thins) a point cloud by keeping points at a fixed interval, a maximum number of points, or a set quantity of first or last points. Remaining points are discarded.  |
        Converts point clouds to point or multipoint geometries, optionally retaining attribute and component values.  |
        Applies a point cloud’s scale, offset, or transformation matrix to it, recalculating component values and removing the transformation values.  |
Point cloud features with both their original geometry and a copy of their geometry encoded as an attribute as specified.
INVALID_FEATURE_CANNOT_WRITE
        Format  |
        The point cloud format used to encode the blob. Choices include:
        Format Name  |
        Name the attribute to contain the selected Format name.  |
        Blob  |
        Name the attribute to contain the encoded Blob.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
Search for all results about the PointCloudExtractor on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
