3DAffiner
Moving, scaling, and rotating 3D geometry.
The 3DAffiner receives features with any geometry type and moves their x, y and z coordinates according to a specified affine transformation.
A 3D affine transformation is a mathematical method of modifying geometry that:
Preserves lines/collinearity: all points on a straight line or plane are still on a straight line or plane after transformation.
Preserves parallelism: lines and planes that are initially parallel are still parallel after transformation.
May not preserve angles, lengths, or areas, depending on the type of transformation performed.
Scaling, mirroring, rotating, shearing, and translating (relocating or offsetting) are all affine transformations. They can be performed singly or in combination.
The 3DAffiner performs 3D transformations, using this formula:
x' = Ax + By + Cz + D
y' = Ex + Fy + Gz + H
z' = Ix + Jy + Kz + L
Where (x,y,z) are the input coordinates and (x',y',z') are the transformed output coordinates.
Description |
Formula/Coefficients |
Example |
| Original 3D Object |
This 3D building model is centered at the origin (0,0,0) and its units are meters. It is not georeferenced. |
| Translate |
Move the geometry a fixed distance. |
Simplified:
Move object 22 meters along all axes:
| Scale |
Shrink or enlarge the geometry. |
Simplified:
Enlarge object by a scale factor of 1.5:
Rotate about X |
Rotate the geometry around the X axis. |
Simplified:
Rotate object by 45 degrees around the X axis:
Rotate about Y |
Rotate the geometry around the Y axis. |
Simplified:
Rotate object by 45 degrees around the Y axis:
Rotate about Z |
Rotate the geometry around the Z axis. |
Simplified:
Rotate object by 45 degrees around the Z axis:
To perform affine transformations in place on geographic features, consider temporary reprojection (Reprojector) to a local coordinate system or using the CommonLocalReprojector.
The Scaler performs 2D and 3D scaling affine transformations, with additional options for specific geometry types and origin handling.
The Offsetter performs 2D and 3D translation affine transformations, with additional coordinate space options (polar and spherical coordinates, in addition to cartesian).
The Rotator and 3DRotator perform rotation affine transformations, with a simplified interface for rotation value, origin (2D) and axis choice (3D).
This transformer accepts any feature. Arcs and ellipses will be stroked to lines and polygons (respectively) before undergoing the transformation.
Features transformed according to parameter selections.
A
Provide values for all coefficients and constants in the affine formula:
Where If a value is not needed for the required transformation, the value should be zero ( |
Dialog Options - Tables
Search for all results about the 3DAffiner on the FME Community.
3D building model by Berlin Partner für Wirtschaft und Technologie GmbH.
