RasterPaletteResolver
Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands.
- Applying palette values to cells to meet format or processing requirements.
- Preparing rasters with palettes to be written to formats that do not support palettes.
The RasterPaletteResolver receives raster features and, for all selected bands, resolves palette values onto bands by replacing cell values with their corresponding palette values. Palettes are removed from the output raster features.
If the palette values have multiple parts, as in RGB palettes, each component part is placed on a separate band, with new bands added as necessary to accommodate them. For example, an input raster feature that has one band with an RGB24 palette will produce an output raster feature with three bands - RED8, GREEN8, and BLUE8 - and no palettes.
This transformer supports raster band selection only. All palettes on the selected band(s) will be resolved. The RasterSelector can be used to modify selection.
If more than one palette is to be resolved, additional bands are added. Band order will reflect the original palette order.
String palettes cannot be resolved, as cell values must be numeric. They should be removed prior to the RasterPaletteResolver, using a RasterSelector and RasterPaletteRemover.
In this example, we have a single-band raster with one RGB palette, and want to resolve the palette values.
Note that the cell selected below has a value of 8, which points to the RGB palette value 253,218,236.
The raster is routed into a RasterPaletteResolver.
There are no parameters to be configured.
The output raster feature has three bands - red, green, and blue - and no palettes. Note that the new bands have retained the raster’s original Nodata Value, which may need to be removed in a subsequent step.
The cell value, previously 8, has been replaced with the palette component values assigned to the appropriate bands.
- New bands duplicate most properties of the original band, including Nodata Value, which may need to be removed or altered after palettes are resolved by using a RasterBandNodataRemover or RasterBandNodataSetter.
- String palettes cannot be resolved and must be removed from selected bands prior to using this transformer, but they may be preserved by using a RasterPaletteExtractor to extract them (as a string) to an attribute That attribute may also be written to a file using an AttributeFileWriter.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with palette values resolved onto bands, with new bands added as required.
INVALID_RASTER_NO_BANDS
INVALID_RASTER_CANNOT_RESOLVE
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the RasterPaletteResolver on the FME Community.
