RasterConsumer
Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features.
- Performance testing or benchmarking raster processing.
- Debugging raster processing.
- Testing raster feature validity.
The RasterConsumer receives raster features and reads all of their data at their current state in the workspace. It does not perform any new operations on the rasters.
FME handles rasters in a “delayed evaluation” model. A raster reader reads essential information about a raster, but does not read the actual cell contents until it is absolutely necessary. Transformer operations are accumulated until the results are needed, often being held until the features enter a writer. At that point, the required data is fully read and processed.
This is intended to optimize performance - for example, if a raster is both clipped and reprojected, FME will optimize processing by not reprojecting data that falls outside of the clip boundary and is ultimately discarded.
The RasterConsumer transformer forces this read to occur, and any accumulated operations are performed as the features are read. Nothing is done with the read features, and the transformer will not improve performance - it simply emulates the effect that reading the data would have, wherever it is placed.
It can be used to test workspace performance without configuring writers, and can also be useful for debugging raster processing workspaces with multiple accumulated operations. It may also be used for raster geometry validation, as it will reject any non-raster features.
Note: Though the transformer has parameters that can be used to adjust the way in which the raster is read (tiles), they are primarily of interest for internal Safe performance testing and are not generally useful in a production environment.
In this example, we are building a raster processing workspace.
The source dataset is a 2 Gb GeoTIFF raster, which needs to be reprojected, then pyramided, and then passed along for further processing.
As both of these operations will be accumulated until they are required (such as enter a writer), we cannot yet determine how long it might take to process this.
A run of the workspace as it stands is very fast, an indication that the two raster operations have been held for later processing.
To get a more accurate idea of how long this will take, we add a RasterConsumer after the two raster processing transformers - the Reprojector and RasterPyramider.
In the parameters dialog, we keep the default settings.
Running the workspace again, we can see that it will take significantly more time to fully read and process the rasters, with the accumulated operations applied.
- The RasterCheckpointer similarly forces processing of any accumulated raster operations, but also writes the current state to a temporary disk file. It may be placed between raster transformers to potentially optimize processing performance and memory usage.
- The Enable Feature Caching option in FME Workbench should be disabled to obtain more accurate processing benchmarks.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with no modifications made.
INVALID_RASTER_NO_BANDS
Note that the default parameter settings are generally used.
Tile Request Order |
Tile (Default): The raster data is read one tile at a time until all tiles are consumed. Several bands may be read for a given tile. Band: The raster data is read one band at a time until all bands are consumed. |
Tile Size |
Use source tile size (Default): The default tile size reported by the band will be used when tiles or bands are consumed. Specify source tile size: The raster will be consumed using the specified Number of Tile Rows and Number of Tile Columns. |
Number of Tile Rows
In conjunction with Specify source tile size, specify the number of rows and columns. |
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the RasterConsumer on the FME Community.
