PointOnRasterValueExtractor
Extracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the point feature.
- Extracting elevations from a DEM and assigning them to point features
- Extracting values from a numeric raster and assigning them to point features
- Extracting color information from a raster and assigning it to point features
The PointOnRasterValueExtractor receives two sets of input features, Raster and Point, which must be in the same coordinate system. Only one raster may be used per group.
At each point’s position, values are interpolated for the corresponding point on the raster for each band and/or palette. A variety of interpolation methods are available. The interpolated values are added to a new list attribute, named _band{}.value and _band{}.palette{}.value, respectively.
Point features are output with the new list attribute, and rasters are discarded.
No attributes will be set for points outside the raster extents.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
In this example, we will extract elevations from a DEM raster (in GEOTIFF format) for the points in a street intersections dataset. The points are shown here, overlaid on the raster. Note that one cell in the raster is selected and Band 0 contains the elevation value.
Both datasets are routed into a PointOnRasterValueExtractor.
In the parameters dialog, the default Interpolation Type of Nearest Neighbor is kept.
Point features are output with elevation values attached as a new list attribute, based on the Nearest Neighbor interpolation. This means the nearest cell center to the point feature provides the new attribute value. As the original raster has only one band, only one value is contained in the list.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster from which values will be extracted. Unless Group By is being used, only one raster will be accepted. Both Raster and Point input should be in the same coordinate system.
Point features to overlay on the Raster input. Both Raster and Point input should be in the same coordinate system.
Point features with interpolated raster values attached as a list attribute.
Group By |
The points may be organized into groups with the Group By parameter, with each group of points having its own reference raster. |
Complete Groups |
![]() There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
Interpolation Type |
Select an interpolation method for determining raster values:
Dialog Options - Tables
Yes |
Dependencies | None |
Aliases | PointOnRasterOverlayer |
History | This transformer was previously named PointOnRasterOverlayer. |
Search for all results about the PointOnRasterValueExtractor on the FME Community.
