NumericRasterizer
Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background.
- Creating single-band numeric raster representations of vector data
- Rasterizing vector polygons as a precursor to raster algebra
- Not used for generating DEMs or overlaying vectors on an existing raster
The NumericRasterizer receives point, line, area or point cloud geometries, and “draws” them onto a numeric (single-band) output raster feature.
Input features must have z coordinates. The cell values for the rendered input features are taken from their z coordinates, and the remainder of the raster is filled with a single specified Background Value, which may also be designated as the raster band’s Nodata value.
The size of the output raster may be defined by number of rows and columns, or by specifying the size of a single cell (pixel) in ground units. The geographic extent covered by the raster may be either determined by the input features or manually specified.
A variety of options is available for raster interpretation type. Anti-aliasing may be used to smooth lines.
The input features are discarded.
If vector features (such as polygons) overlap, then the value of the cell in those overlaps comes from the last feature to arrive.
Rendering non-elevation values: 3DForcer
Vector features often represent non-elevation data. To produce a numeric raster representation of those vectors with a NumericRasterizer, the value to be represented needs to be stored in the z coordinate of the source data.
To accomplish this, use the 3DForcer transformer prior to the NumericRasterizer, and assign the desired values to the features’ z coordinates.
In this example, we will create a numeric raster where the cell values represent a zoning type. The source data is a set of polygons. Note that the data has attributes containing the zoning information - ZoneCategory and ZoneName. Both attributes are strings.
The source dataset’s coordinate system is UTM83-10, and so the ground units will be meters.
Three steps are required to convert these polygons to a numeric raster:
- Add a numeric value by mapping an attribute value to a corresponding set of numbers.
- Assign the newly created numeric values to the features’ z coordinates.
- Rasterize the polygons.
The input polygons are first routed into an AttributeValueMapper, where numeric values are assigned. In the parameters dialog, Source Attribute is set to ZoneCategory, and Destination Attribute (the new attribute) is named Key.
The Import… button reads in all possible values for ZoneCategory, and new numeric Destination Values are manually assigned in the Value Map table.
Next, the features are routed into a 3DForcer. In the parameters dialog, Elevation is set to the Key attribute that was created by the AttributeValueMapper.
Finally, the features are sent to the NumericRasterizer. In the parameters dialog, the output raster size is determined by setting Resolution Specification to Cell Spacing, and both the X and Y Cell Spacing to 1 - producing 1 meter square cells.
Interpretation Type is set to UInt8, an 8-bit unsigned integer. The Background Value is zero (0), which will be assigned to any cells that fall outside the area our input polygons cover. Fill Background with Nodata is set to Yes, which will designate zero (0) as the raster band’s Nodata value.
The output raster feature has one band, and the background cells with the Nodata value are rendered transparently as viewed in the FME Data Inspector.
The cell values reflect the numeric values created and assigned with the AttributeValueMapper and the 3DForcer.
- To rasterize vector or point cloud features into a color raster, consider using the ImageRasterizer or MapnikRasterizer.
- The NumericRasterizer does not interpolate cell values as might be required when using point-based features such as elevations or weather stations. If interpolation is required, consider using the RasterDEMGenerator, DEMGenerator, or SurfaceModeller.
- To carry out raster algebra on rasterized polygons, use either the RasterExpressionEvaluator or RasterCellValueCalculator transformers.
- To rasterize vector data onto an existing raster feature, consider using the VectorOnRasterOverlayer or MapnikRasterizer.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Point, line, area, or point cloud features to be rasterized. Input features must have a z coordinate from which cell values will be assigned.
A single band numeric raster created according to parameter selections.
Invalid features will be routed to the <Rejected> port.
INVALID_VECTOR_GEOMETRY_TYPE
INVALID_VECTOR_GEOMETRY_DIMENSION
Group By |
If the Group By parameter is set to an attribute list, one raster per group will be produced. |
Complete Groups |
![]() There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
Resolution Specification |
Select a method of defining output raster size:
Number of Columns (cells) |
If Resolution Specification is Rows and Columns, enter the width of the output raster in cells (pixels). |
Number of Rows (cells) |
If Resolution Specification is Rows and Columns, enter the height of the output raster in cells (pixels). |
X Cell Spacing |
If Resolution Specification is Cell Spacing, enter the width in ground units of a single cell (pixel). |
Y Cell Spacing |
If Resolution Specification is Cell Spacing, enter the height in ground units of a single cell (pixel). |
Interpretation Type |
Select an interpretation for the output raster. Options include:
Background Value |
Sets the background value for cells not covered by rendered input features. The value must be within range of the chosen Interpretation Type. |
Fill Background with Nodata |
If Yes, the background value will also be flagged as the Nodata value for the raster band. |
Anti-Aliasing |
If Yes, the output lines will be smoothed using an anti-aliasing algorithm. |
Tolerance |
The Tolerance parameter is the maximum normalized distance from a line segment or polygon vertex to a pixel to be rendered. For example a tolerance of 1.0 will draw all pixels touched by the input vector line, while a tolerance of 0.0 will draw only those pixels where the input vector line passes directly through their center. The default tolerance is 0.5. Tolerance can only be selected when Anti-Aliasing is set to No. |
Ground Extents |
If Use input data ground extents, the extents are not explicitly specified, and the output raster extents will be determined by the union of the bounding boxes of the valid input vector features. If Specify ground extents, the remaining Ground Extents parameters are used to specify the extents of the output raster. The output raster will be clipped to the specified extents. |
Minimum X |
This specifies the minimum x value of the output raster. It is used when the Ground Extents parameter is set to Specify ground extents. |
Minimum Y |
This specifies the minimum y value of the output raster. It is used when the Ground Extents parameter is set to Specify ground extents. |
Maximum X |
This specifies the maximum x value of the output raster. It is used when the Ground Extents parameter is set to Specify ground extents. |
Maximum Y |
This specifies the maximum y value of the output raster. It is used when the Ground Extents parameter is set to Specify ground extents. |
Dialog Options - Tables
Yes |
Dependencies | None |
Aliases | |
History |
Search for all results about the NumericRasterizer on the FME Community.
