PointCloudCombiner
- Combining multiple point clouds into a single feature
- Converting non-point cloud features to a point cloud in order to process them against point cloud features
- Converting non-point cloud geometry to a point cloud to take advantage of processing efficiency gains
The PointCloudCombiner receives one or more features and combines them into a single point cloud output feature, converting geometry to point clouds if necessary.
When combining multiple input features, all features must be in the same coordinate system, regardless of geometry type.
Attributes and measures may optionally be preserved as point cloud components.
The various input geometry types are each handled differently.
Point Clouds
Input point cloud features are simply combined with no further modifications. They may be combined with additional point clouds and/or any other input geometry type.
Vectors
Vectors are converted as follows:
- Point and curve features are converted vertex for vertex - that is, each vertex in the vector geometry will produce a point in the point cloud.
- Polygonal, donut, surface and solid features are converted into a grid of points lying inside the area on the 3D plane represented by the area’s calculated normal. The density of the grid may be adjusted with the Point Interval parameter.
Rasters
Rasters are converted as follows:
- The x and y components are created from the cell ground coordinates, or columns and rows if the raster has no coordinate system.
- The first selected numeric band will become the z component.
- The first selected bands with red/green/blue/gray interpretations will become the color_red/color_green/color_blue components.
- Additional selected bands will also be preserved. If the band has a name, the component name will be the band name. If the band has no name, the component name will be bandN, where N is the band index.
- Nodata may optionally be extracted.
In this example, we will simply combine two point cloud features into one. Note the two input features are adjacent - and are in the same coordinate system.
The point cloud features are routed into a PointCloudCombiner.
There are no parameters that need to be set for this basic operation - the default settings in the parameters dialog do not need to be changed.
One point cloud feature is output. Note that the point count reflects all points from both input features.
In this example, we will convert a digital elevation model (DEM) raster feature to a point cloud, so that it may be used with other point cloud data.
Note that the input raster has one numeric band, type INT32 (32-bit integer).
Each cell has x and y ground coordinates, and an elevation value stored in Band 0.
The raster feature is routed into a PointCloudCombiner.
In the parameters dialog, the default settings are fine - including the Raster Parameters > Extract Nodata setting of No.
One point cloud feature is output, which contains one point for every cell in the input raster.
Each point has x and y component values from the original cell, and the z component contains elevation from the numeric raster band. The point cloud is viewed here at an oblique angle in 3D in the FME Data Inspector.
- When combining multiple input features (regardless of format), they must be in the same coordinate system. The CoordinateSystemSetter and Reprojector transformers may be useful.
Features to be combined into a point cloud. All geometry types are supported. Non-spatial is not supported.
A single point cloud feature containing all input features, converted to point cloud if necessary, with components and component values as specified.
INVALID_GEOMETRY_NONSPATIAL
INVALID_GEOMETRY_COORDINATE_SYSTEM
Group By |
Use this parameter to organize input features into groups. Each group will have its own output point cloud. |
Complete Groups |
There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
Accumulate Attributes |
If Yes, the attributes from the original features will be merged onto the output point cloud features. |
Extract Nodata |
Specifies whether points should be created for Nodata cells in rasters:
A cell is considered to be Nodata when, for each selected band, the value for that cell is equal to that band's Nodata value. If any cell value is not equal to that band's Nodata value, the cell will be considered data. |
Point Interval |
If converting surfaces, solids, areas or donuts, specify the spacing between points (in ground units) to be used to generate the representative point grid. |
If input vector geometries have measures to be kept, add one line per measure in this table.
Measure |
Specify the name of the measure to be converted to a point cloud component. |
Data Type |
Specify the measure’s numeric data type. |
If input features have attributes to be kept, add one line per attribute in this table.
Note that if the same component is specified as both a Measure and Attribute to Preserve, the measure value will be preferred.
Attribute |
Specify the name of the attribute to be converted to a point cloud component. |
Data Type |
Specify the attribute’s string or numeric data type. |
Combined Count |
Name the attribute to contain the number of features that were combined to create the point cloud feature. |
Dialog Options - Tables
Yes |
Search for all results about the PointCloudCombiner on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
