Transformer Parameter Menu Options
Most transformer parameters are now integrated so that the options can be easily configured with other elements in the workspace.
This means that the parameters can be set, changed, published or unpublished, set to an attribute value, or linked to another parameter. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers.
Accessing the Parameter Menu
The options that will appear for a transformer depend on the type of transformer that you are using. If the transformer supports it, the menu displays after you open the transformer properties and click the parameter menu
button on the right side. This menu will usually display different options for each transformer parameter. The most common parameters are described below.
Common Menu Options
These menu choices are available in most transformers:
| Menu Choice | Available | Description |
For all parameters except transformer name and new attribute names |
This will set the value of the parameter to a user, system, FME Flow, or FME deployment parameter. There are three ways you can set to a parameter:
Always |
Clears all values and returns the parameter to an empty state. For choice parameters, Clear Value will take you back to the drop-down list. |
If the parameter can take the value of an existing attribute from the input feature |
Set a parameter value to the value of an existing attribute. Even if the parameter takes only a simple Yes/No value, you might want to ensure that you carry this value through to other transformer parameters without having to explicitly set them. |
Other Menu Options
Some parameter menu choices that appear depend on the transformer parameter type. Because each transformer parameter is unique, the associated parameter menu is also unique.
The table below lists some of the more common transformer-specific options:
| Menu Choice | Description |
Opens a dialog that allows you to choose multiple list items. For example, all transformer Group By parameters display this menu choice. |
Select an attribute from the list. |
In transformers that include font definitions, this menu choice displays the font chooser dialog. |
Opens a dialog that allows you to input an arithmetic equation, such as “1+2”, that will be evaluated at runtime. |
Opens the text editor. |
Opens a Regular Expression Editor. |
For any parameters that accept color definitions, this menu choice opens a color picker specific to the operating system. |
For any parameters that accept coordinate system definitions, this menu choice opens the Coordinate System Gallery. |
Opens a folder/file browser in transformer parameters that require folders or files as input. |
Select Format |
Allows you to select the format of a reader or writer. |
Select Raster |
Opens a dialog that allows you to select raster bands and palettes. |
When selected in transformers that work with XML files, provides the option of opening a file browser or specifying an attribute. |
Opens a dialog that allows you to define geometry. |
Function Return |
Parameter is set to the value returned by a function. |
Opens the Parameter Condition Definition dialog. |
If the value cannot be set automatically, the translation is stopped. |
The value of the attribute is left ‘as is’ without being modified. |
The parameter is assigned a value of null. |
User Parameter
Clear Value
Attribute Value
Change Selection
Choose Font
Open Arithmetic Editor
Open Text Editor
Select Color
Select Coordinate System
Select Folder/Source Filename/Dataset File/Image/FME Workspace
Select XML.
Set Geometry
Conditional Value
Stop Translation
No Action
Null
