Reprojector
Reprojects feature x and y coordinates from one coordinate system to another.
Jump to Configuration
  • Performing simple reprojections, without z value handling.
The Reprojector receives vector, raster, or point cloud features and reprojects their x and y coordinates from one coordinate system to another, generally using the FME (CS-Map) library.
This transformer will honor the Workspace Parameter Reprojection Engine, and will use the Esri Reprojection Engine if it is selected there, with or without an Esri product being installed.
The Source Coordinate System may be either read from the input feature or specified explicitly, and the Destination Coordinate System must be specified. Both may be set by selecting from the Coordinate System Gallery or by name via an attribute value or user parameter.
The Reprojector does not reproject z values.
Dynamic Coordinate Systems
Features may be reprojected to a dynamic Destination Coordinate System - that is, a local coordinate system that is created specifically for each individual feature. This is often used for tasks such as taking measurements or creating geometry in meters or other ground units, on data with geographic (latitude and longitude) coordinates.
There are two types available:
  • _AZMEA_ (Dynamic Reprojection Equal Area) - Better for preserving area accuracy
  • _AZMED_ (Dynamic Reprojection Equal Distance) - Better for preserving distance accuracy
In either case, the input feature is reprojected to a local coordinate system centered on its bounding box. Though all the output features will be centered on a common origin (with the exception of features located very near the poles) and appear stacked on top of each other, each one retains the specifics of its reprojection (and so original position), and can be safely reprojected back into a projected or geographic coordinate system.
Note that Z values are not considered, so areas or distances are best preserved for geometry at an ellipsoid height of 0 meters.
Note: To calculate and reproject to a single AZMED or AZMEA coordinate system that encompasses all input features, consider using the CommonLocalReprojector.
Rasters
Additional parameters are available for raster features, specifying how the reprojected cells are to be interpolated.
This transformer is not affected by raster band and palette selection.
  • This transformer does not alter z values. For handling elevation or vertical coordinate systems, consider using a CsmapReprojector.
  • For finer control, including Geographic Transformation selections, consider using a CsmapReprojector or EsriReprojector.
  • Some geographic areas have their own reprojection libraries and transformers. See Working with Coordinate System Transformers below.
  • This transformer operates on features with geometry. To reproject coordinates stored as attributes, see the AttributeReprojector or CsmapAttributeReprojector.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community is the place for demos, how-tos, articles, FAQs, and more. Get answers to your questions, learn from other users, and suggest, vote, and comment on new features.
Search for all results about the Reprojector on the FME Community.
