CoordinateExtractor
- Extracting coordinate values into attributes for manipulation or use elsewhere.
The CoordinateExtractor receives any type of geometry, and retrieves either one specified coordinate or all coordinates, adding them to the feature as attributes.
If Specify Coordinate is used, retrieving only one coordinate, the coordinate is identified by its Coordinate Index, which may be either entered as an integer or specified with an attribute value, expression, user parameter, or conditional value. A coordinate index always starts at zero (0). 0 indicates the first vertex (or only vertex of a point geometry), and a negative index can be used to indicate position relative to the last vertex where -1 is the last coordinate, -2 is the second-to-last, and so on. If the index number is invalid, the feature will be rejected.
If All Coordinates is used, retrieving coordinates for all vertices, the values will be added to a list attribute which may be further manipulated with list-based transformers. A list is returned even when the incoming feature possesses just a single vertex.
A Default Z Value may be optionally provided, and is applied where no z coordinate value exists.This too can be provided by an attribute, expression, user parameter, or conditional value.
If the input feature is a raster or point cloud, All Coordinates will return its extents, and Specify Coordinate will return the requested vertex on the bounding box (0, 1, 2, 3, 4). If the input feature is multi-part or aggregate, each part’s coordinates are indexed sequentially.
In this example, we have a geodatabase containing address points. Note that the point features have 23 attributes, and are in a UTM coordinate system. We want to extract the coordinates of each point into attributes for use elsewhere.
The address points are routed into a CoordinateExtractor.
In the parameters dialog, Mode is set to Specify Coordinate. The Coordinate Index default is zero (0), the first one, which is correct. Default names are also provided for the X, Y, and Z output attributes.
Note that although Mode > All Coordinates would also return just one set of coordinates per point, and wouldn’t require setting a Coordinate Index number, they would be added as a list attribute, potentially requiring additional transformers to work with.
The output features have two added attributes - _x and _y - for a new total of 25 attributes. Note that the coordinate values are in meters due to the UTM coordinate system.
The Z Attribute was not added, as the data is 2D and we did not provide a Default Z Value.
In this example, we have a set of park polygons, and want to retrieve all of the coordinates for them. Note that the input features have 28 attributes.
The features are routed into a CoordinateExtractor.
In the parameters dialog, Mode is set to All Coordinates. A default name is provided for the Coordinates List Name - _indices.
The output features have an added list attribute named _indices containing coordinates for each vertex of the polygon.
Note that each coordinate has an x and y value only. Z was not added as the data is 2D and we did not provide a Default Z Value.
In this example, we want to retrieve the coordinates of the first and last points of these transit lines. Note that the original features have nine attributes.
The features are routed through two CoordinateExtractors, one to extract the first point and one to extract the last.
In the parameters dialog of the first CoordinateExtractor, Mode is set to Specify Coordinate and Coordinate Index is set to zero (0), indicating the first vertex.
The X and Y Attribute names are edited to start_x and start_y.
Similarly, in the parameters dialog of the second CoordinateExtractor, Coordinate Index is set to -1, indicating the last vertex. X and Y Attribute are set as end_x and end_y.
The output features have added attributes containing the requested coordinate values.
- Extracted coordinates may be reprojected into another coordinate system using the AttributeReprojector.
- All vertices can be retrieved as a delimited attribute (instead of a list) using the CoordinateConcatenator.
- The first coordinate index is 0 and the last coordinate index is -1. In a polygon feature, or a line feature that closes on itself, these two vertices should return the same coordinate values.
- To retrieve the center point of a feature, use the CenterPointExtractor or CenterPointReplacer.
Features with extracted coordinates stored in either attributes or list attributes as specified in the parameters.
Features where either an invalid Coordinate Index or invalidDefault Z Value has been provided will be routed to the <Rejected> port.
INVALID_PARAMETER_DEFAULT_Z
INVALID_PARAMETER_INDEX
Mode |
Select a coordinate extraction mode. Choices include: All Coordinates: extract coordinates from all vertices on the geometry. If point cloud or raster, extract the feature’s extents. Specify Coordinate: Extract coordinate values for one specified vertex. |
Default Z Value |
Optionally provide a z value to be applied to 2D geometries. If blank, no z attributes will be created where they do not already exist. |
Coordinates List Name |
If Mode is All Coordinates, provide a name for the list attribute to be added and store all coordinate values. The default name is _indices. |
Coordinate Index |
If Mode is Specify Coordinate, specify the index position of the desired coordinate as an integer. Attribute values and expressions are supported. Index numbering starts at zero (0), indicating the first vertex. Negative index positions indicate position relative to the last vertex, where -1 is the last, -2 is second-to-last, and so on. |
Output Attribute Names
X |
Name the attribute to contain the x coordinate. |
Y |
Name the attribute to contain the y coordinate. |
Z |
Name the attribute to contain the z coordinate. |
Dialog Options - Tables
| Aliases | CoordinateFetcher |
Search for all results about the CoordinateExtractor on the FME Community.
