ElevationExtractor
Extracts a feature’s first z coordinate value, storing it in an attribute.
Extracting elevations from geometry to an attribute for further processing.
The ElevationExtractor receives any type of geometry and extracts the z coordinate value of the feature’s first coordinate into an attribute.
If the input feature is 2D, the Elevation output attribute will receive a value of zero (0).
Rasters, including elevation models, will also receive an elevation value of zero (0).
Dialog Options - Tables
Search for all results about the ElevationExtractor on the FME Community.
