CoordinateSwapper
Swaps coordinate axes of the input features.
Correcting reversed latitude and longitude coordinates
Producing cross-sections
Data QA
The CoordinateSwapper receives features of any geometry type, and swaps the coordinate values of two of its axes - x and y, x and z, or y and z.
This transformer does not alter attribute values - only geometry coordinate values. Features without geometry are passed through unaltered.
In this example, we have a set of GPS points in which the x and y coordinates have been incorrectly designated. Examining one point, we see that x appears to be a latitude value and y a longitude value - they should be the reverse.
The points are routed into a CoordinateSwapper.
In the parameters dialog, Swap Type is set to X <-> Y.
The output features have their x and y coordinates corrected.
To alter coordinates stored as attribute values (not geometry), consider using the AttributeManager.
Features with geometry.
Features with axes swapped as specified in parameters.
Swap Type |
Select which pair of coordinates to swap:
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the CoordinateSwapper on the FME Community.
