ReprojectAngleCalculator
Converts a given angle from one coordinate system to another.
- Determining angles for text and symbol rotation
- Reprojecting angles stored as attribute values
The ReprojectAngleCalculator receives features with geometry and reprojects a given angle from one coordinate system to another.
The transformer starts with two points. One is the first coordinate of the input feature’s geometry, and the second is calculated from that point using the Original Line Angle and Original Line Length. Both of these points are reprojected from the Source Coordinate System to the Destination Coordinate System. A new angle is calculated from the reprojected points and added to the output feature as an attribute value.
The Original Line Angle may be provided as an attribute value, constant value, expression, user parameter, or conditional value.
Original Line Length is also required to perform the calculation, in the Source Coordinate System’s ground units. The length may be provided as an attribute, expression, constant, parameter, or conditional value. A length of one (1) is often appropriate for calculating rotation around a point, such as text and symbol rotation angles.
Both the Source and Destination Coordinate Systems must be specified explicitly.
Reprojections are generally performed using the FME (CS-Map) library, however, this transformer will honor the Workspace Parameter Reprojection Engine, and will use the Esri Reprojection Engine if it is selected there, with or without an Esri product being installed.
Z values are not supported.
This transformer assumes all coordinate systems are Cartesian.
In this example, we have a CAD file containing traffic signal locations and labels. The original file is projected as UTM83-10, but we want to know what will happen to the label rotation if we reproject to BCPOLY-83.
Note that the label's autocad_rotation value is zero (0).
The features are routed into a ReprojectAngleCalculator.
Note that three format-specific attributes have been exposed - autocad_text_size, autocad_text_string, and autocad_rotation. This was done in the Autodesk AutoCAD DWG/DXF Reader parameters, Format Attributes, so that we can access their values.
In the parameters dialog, we set Original Line Angle to the exposed autocad_rotation attribute, and the Original Line Length to 1 (meter, in ground units).
Both the Source and Destination Coordinate Systems are specified explicitly.
The Reprojected Angle Attribute is named _angle (the default name).
The output feature has a new attribute - _angle - with the value of the reprojected angle.
Note that the Coordinate System has not changed and is still UTM83-10. The feature itself has not been reprojected, its geometry not altered. The reprojection to BCPOLY-83 has only been used to calculate the _angle value.
- This transformer requires that features have geometry to provide an initial coordinate. Non-spatial features will not produce valid output. To create geometry for non-spatial data with coordinates as attributes, consider using a VertexCreator.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII reprojection library. This library allows you to use the GridInQuestIIReprojector to transform coordinates between ETRS89 (WGS84) and the national coordinate systems of Great Britain, Northern Ireland and the Republic of Ireland. |
Sweden |
Sweden |
Switzerland |
Reprojects feature coordinates from one coordinate system to another using the REFRAME library. This transformer handles the usual planimetric and altimetric reference frame change for Switzerland. |
Features with geometry.
Features with a reprojected angle value added to an attribute.
Original Line Length |
Specify a distance, in the Source Coordinate System’s ground units. |
Original Line Angle |
Specify an angle, in the Source Coordinate System. Angle is measured counterclockwise from horizontal in degrees. |
Source Coordinate System |
Specify the coordinate system of the input features. |
Specify the coordinate system the Original Line Angle is to be reprojected to. Note that the feature itself will not be reprojected, and this parameter is only used for calculation of the Reprojected Angle Attribute. |
Reprojected Angle Attribute |
Name the attribute to contain the reprojected angle value. |
Dialog Options - Tables
Search for all results about the ReprojectAngleCalculator on the FME Community.
