CoordinateSystemSetter
Assigns a user-specified coordinate system to features, without modifying geometry or coordinates.
- Adding missing coordinate system designations
- Adding coordinate system designations when the feature's original format does not support them
- Fixing incorrect coordinate system designations
The CoordinateSystemSetter receives any feature and assigns a user-specified coordinate system to it. No geometry is modified, and data is not reprojected.
The coordinate system may be entered explicitly or set to an attribute value, user parameter, or conditional value.
If a feature already has a coordinate system assigned, it will be overwritten.
In this example, we have a DWG (CAD) file of one-way streets. Though DWG files can come with coordinate system information attached, this one does not have it. Note that the extents of the selected feature would be appropriate coordinates for a UTM coordinate system.
We do know that the data is in UTM83-10, and need to assign that coordinate system to the data without modifying the feature geometry.
The features are routed into a CoordinateSystemSetter.
In the parameters dialog, Coordinate System is set to UTM83-10.
The output features now know their coordinate system, and the coordinates themselves have not been modified.
- If the coordinate system is not known, this transformer cannot be used to determine it. You will need to assess the units and extents of the coordinates to try to make a manual determination.
- Similarly, FME won’t carry out checks to ensure that any coordinate system selected is appropriate to the current data.
- You don’t need to use this to tag features before reprojecting them, as long as the reprojection is done via a transformer. Set the coordinate system in the chosen reprojection transformer’s Source Coordinate System parameter.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII reprojection library. This library allows you to use the GridInQuestIIReprojector to transform coordinates between ETRS89 (WGS84) and the national coordinate systems of Great Britain, Northern Ireland and the Republic of Ireland. |
Sweden |
Sweden |
Switzerland |
Reprojects feature coordinates from one coordinate system to another using the REFRAME library. This transformer handles the usual planimetric and altimetric reference frame change for Switzerland. |
Features with a new coordinate system assigned as specified in parameters.
Coordinate System |
Specify a coordinate system to be assigned to all input features. |
Dialog Options - Tables
Search for all results about the CoordinateSystemSetter on the FME Community.
