CoordinateSystemExtractor
Retrieves the name of the feature's assigned FME coordinate system into an attribute.
- Identifying the coordinate system of a feature or dataset.
The CoordinateSystemExtractor receives any type of geometry and retrieves its FME coordinate system name, adding it to the features as an attribute.
If the input feature does not have a coordinate system defined, or if its coordinate system is not present in the FME coordinate systems file , the attribute will have an empty value.
In this example, we have a shapefile of transit lines. Note that the FME Data Inspector knows what the coordinate system is and displays it, but that information is not readily accessible in attribute form.
The transit lines are routed into a CoordinateSystemExtractor.
In the parameters dialog, we keep the default Coordinate System Attribute name of _coordsys.
The output features now have the coordinate system name stored as a new attribute.
- To convert the FME coordinate system name to another format such as EPSG number or OGC WKT, use the CoordinateSystemDescriptionConverter.
- To manually assign a coordinate system, use the CoordinateSystemSetter.
- For more information, see Working with Coordinate Systems.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII reprojection library. This library allows you to use the GridInQuestIIReprojector to transform coordinates between ETRS89 (WGS84) and the national coordinate systems of Great Britain, Northern Ireland and the Republic of Ireland. |
Sweden |
Sweden |
Switzerland |
Reprojects feature coordinates from one coordinate system to another using the REFRAME library. This transformer handles the usual planimetric and altimetric reference frame change for Switzerland. |
Features with the extracted coordinate system name stored as an attribute.
Coordinate System Attribute |
The name of the attribute to contain the extracted coordinate system name. |
Dialog Options - Tables
| Aliases | CoordinateSystemFetcher |
Search for all results about the CoordinateSystemExtractor on the FME Community.
