LocalCoordinateSystemSetter
Assigns a specified local coordinate system to features, without modifying geometry or coordinates.
- Adding missing local coordinate systems
- Adding local coordinate systems when the features’ original format does not support them.
- Fixing incorrect local coordinate systems
The LocalCoordinateSystemSetter receives any feature and assigns a specified local coordinate system to it. No geometry is modified, and data is not reprojected.
The local coordinate system may be either Equidistant (AZMED) or Equal Area (AZMEA), and a choice of ground units is provided.
The local coordinate system is mapped to a true coordinate system by selecting that coordinate system and entering the X and Y coordinates that match 0,0 in the local coordinate system
Note that Z coordinates are not considered, and so areas or distances are best preserved for geometry at an ellipsoid height of zero (0) meters.
If a feature already has a coordinate system assigned (local or otherwise), it will be overwritten.
In this example, we have an OBJ file containing a 3D model of a public library. Note that the Coordinate System is Unknown, and that the extents would be appropriate coordinates for a local coordinate system.
We know what the local coordinate system should be, and so need to assign it without modifying the feature geometry.
The feature is routed into a LocalCoordinateSystemSetter.
In the parameters dialog, we select a Projection Type of Equidistant (AZMED) and Projection Units of Meters.
Origin coordinates are entered as Lat/Long NAD83.
The output feature now knows its local coordinate system. Note that the extents are unchanged, as the feature’s coordinates have not been modified. .
- If ground units need adjustment to match the coordinate system, consider using a Scaler prior to this transformer.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII reprojection library. This library allows you to use the GridInQuestIIReprojector to transform coordinates between ETRS89 (WGS84) and the national coordinate systems of Great Britain, Northern Ireland and the Republic of Ireland. |
Sweden |
Sweden |
Switzerland |
Reprojects feature coordinates from one coordinate system to another using the REFRAME library. This transformer handles the usual planimetric and altimetric reference frame change for Switzerland. |
Features with a new coordinate system assigned as specified in parameters.
Projection Type |
Select a Projection Type based on whether preservation of distances or areas will be more important during subsequent reprojections. Choices include:
Projection Units |
Choose the units of the features that will be entering the transformer. Choices include:
Origin Coordinate System |
Specify the coordinate system of the origin point. The created local coordinate system will be based on the datum of this coordinate system. |
Origin X |
Specify the X coordinate of the point that corresponds to 0,0. |
Origin Y |
Specify the Y coordinate of the point that corresponds to 0,0. Origin points within 0.5 degree of the North or South Pole will cause an error. |
Dialog Options - Tables
Search for all results about the LocalCoordinateSystemSetter on the FME Community.
