LocalCoordinateSystemSetter
Assigns a specified local coordinate system to features, without modifying geometry or coordinates.
- Adding missing local coordinate systems
- Adding local coordinate systems when the features’ original format does not support them.
- Fixing incorrect local coordinate systems
The CoordinateSystemSetter receives any feature and assigns a specified local coordinate system to it. No geometry is modified, and data is not reprojected.
The local coordinate system may be either Equidistant (AZMED) or Equal Area (AZMEA), and a selection of ground units is provided. X and Y origin coordinates must be entered, as well as their coordinate system.
Note that Z coordinates are not considered, and so areas or distances are best preserved for geometry at an ellipsoid height of zero (0) meters.
If a feature already has a coordinate system assigned (local or otherwise), it will be overwritten.
In this example, we have an OBJ file containing a 3D model of a public library. Note that the Coordinate System is Unknown, and that the extents would be appropriate coordinates for a local coordinate system.
We know what the local coordinate system should be, and so need to assign it without modifying the feature geometry.
The feature is routed into a LocalCoordinateSystemSetter.
In the parameters dialog, we select a Projection Type of Equidistant (AZMED) and Projection Units of Meters.
Origin coordinates are entered as Lat/Long NAD83.
The output feature now knows its local coordinate system. Note that the extents are unchanged, as the feature’s coordinates have not been modified. .
FME inherently supports coordinate system transformations and reprojections, using the CS-Map coordinate system library.
Coordinate System Support
These transformers perform various coordinate system-related tasks, but do not reproject the data. If a coordinate system library is required for a task, CS-Map is used.
Converts coordinate system names and definitions between FME’s internal format and common third-party and open source representations, storing the results as an attribute. |
Retrieves the FME coordinate system name of the feature into an attribute. |
Different coordinate system libraries (engines) not only contain coordinate system definitions, they also have unique reprojection algorithms. FME’s generic reprojection transformers, in the first table below, use CS-Map. A selection of other libraries is also available, some of which are specific to certain areas of the world or certain software platforms.
Default reprojections, as in a workspace with different input and output coordinate systems selected, are performed with the CS-Map library, also the equivalent of using the generic Reprojector transformer.
If you are reprojecting explicitly with a transformer in the workspace, using library-specific transformers is recommended. In the case of CsmapReprojector versus the Reprojector, the library is identical, but the CSMapReprojector handles vertical coordinate calculations whereas the Reprojector does not.
Library |
CS-Map |
CS-Map |
CS-Map |
Converts a given distance from one coordinate system to another. |
CS-Map |
CS-Map |
Library (External Links) |
Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII reprojection library. This library allows you to use the GridInQuestIIReprojector to transform coordinates between ETRS89 (WGS84) and the national coordinate systems of Great Britain, Northern Ireland and the Republic of Ireland. |
Sweden |
Reprojects attributes holding coordinate values from one coordinate system to another using the Gtrans reprojection library (from the National Land Survey of Sweden), and the specified translation file. |
Sweden |
Reprojects features from one coordinate system to another using the Gtrans reprojection library (from the National Land Survey of Sweden) and the specified translation file. |
Reprojects attributes from one coordinate system to another using the PROJ library. |
Switzerland |
Reprojects feature coordinates from one coordinate system to another using the REFRAME library. This transformer handles the usual planimetric and altimetric reference frame change for Switzerland. |
Features with a new coordinate system assigned as specified in parameters.
Projection Type |
Select a Projection Type based on whether preservation of distances or areas will be more important during subsequent reprojections. Choices include:
Projection Units |
Choose the units of the features that will be entering the transformer. Choices include:
Origin Coordinate System |
Specify the coordinate system of the origin point. The created local coordinate system will be based on the datum of this coordinate system. |
Origin X |
Specify the X coordinate of the point that corresponds to 0,0. |
Origin Y |
Specify the Y coordinate of the point that corresponds to 0,0. Origin points within 0.5 degree of the North or South Pole will cause an error. |
Dialog Options - Tables
Search for all results about the LocalCoordinateSystemSetter on the FME Community.
