CsmapAttributeReprojector
Reprojects coordinates stored as attributes from one coordinate system to another using the CS-MAP library.
- Reprojecting coordinates stored as attributes when explicitly using the CS-Map library is desired
- Reprojecting coordinates stored as attributes with Z values
- Performing reprojections with finer control than the AttributeReprojector transformer provides
The CsmapAttributeReprojector accepts any feature. The user specifies attributes containing X, Y, and optionally Z coordinates, and supplies both the Source and Destination Coordinate Systems.
The transformer reprojects the coordinates according to these selections, using the CS-Map library, and updates the X, Y, and Z Attributes to the new values. The original values are overwritten.
This transformer does not alter the feature’s geometry – only the values of the selected X, Y, and Z Attributes (if they contain coordinate values) are changed.
Accurate results depend on the user’s correct selection of the source coordinate system.
The CS-Map library is FME’s default library, and so is generally used for most transformations. Using this transformer explicitly ensures that this library is used, and also provides options for handing Z (vertical) values.
Dynamic Coordinate Systems
Features may be reprojected to a dynamic Destination Coordinate System - that is, a local coordinate system that is created specifically for each individual feature. This is often used for tasks such as taking measurements or creating geometry in meters or other ground units, on data with geographic (latitude and longitude) coordinates.
There are two types available:
- _AZMEA_ (Dynamic Reprojection Equal Area) - Better for preserving area accuracy
- _AZMED_ (Dynamic Reprojection Equal Distance) - Better for preserving distance accuracy
In either case, the input feature is reprojected to a local coordinate system centered on its bounding box. Though all the output features will be centered on a common origin (with the exception of features located very near the poles) and appear stacked on top of each other, each one retains the specifics of its reprojection (and so original position), and can be safely reprojected back into a projected or geographic coordinate system.
Note that Z values are not considered, so areas or distances are best preserved for geometry at an ellipsoid height of 0 meters.
Note: To calculate and reproject to a single AZMED or AZMEA coordinate system that encompasses all input features, consider using the CommonLocalReprojector.
Geographic Transformations
Geographic Transformations control how coordinates are converted between different datums.
The default Transformation is <Auto> (or blank), which will look for an appropriate transformation between datums, if one is needed.
If an explicitly selected pair of coordinate systems has one or more geographic transformations available, they will be provided for explicit selection.
If set to <None>, the NULL_FME transformation will be used which does not alter the value of any coordinates.
In this example, we have a CSV file containing Community Gardens, along with their address and latitude/longitude coordinates. The features have no geometry - the coordinates are simply stored as attribute values.
We want to add a second of coordinates, also as attributes, in an appropriate UTM coordinate system.
This will take two steps - first, the features are routed into an AttributeManager to create a copy of the coordinates, and then to a CsmapAttributeReprojector to reproject them.
In the parameters dialog of the AttributeManager, we add the two new attributes X_COORD and Y_COORD, and copy the values from LONGITUDE and LATITUDE.
In the parameters dialog of the CsmapAttributeReprojector, we set the Source and Destination Coordinate Systems to LL84 and UTM83-10, respectively. Transformation is left as default, <Auto>.
As the data is 2D, Vertical Handling is left as its default, Ignore heights and leave them unchanged.
The X Attribute and Y Attribute are mapped to the attributes we just added with the AttributeManager.
The output features still have no geometry, and now contain a second set of reprojected coordinates, for UTM Zone 10 NAD83.
- FME also has a Workspace Parameter, Reprojection Engine, that may be set to either FME (CS-Map) or Esri. This transformer will override this parameter setting.
- The AttributeReprojector provides similar functionality, and will use the default library (CS-Map or Esri) set in FME. It does not handle z values.
FME inherently supports coordinate system transformations and reprojections, using the CS-Map coordinate system library.
Coordinate System Support
These transformers perform various coordinate system-related tasks, but do not reproject the data. If a coordinate system library is required for a task, CS-Map is used.
Converts coordinate system names and definitions between FME’s internal format and common third-party and open source representations, storing the results as an attribute. |
Retrieves the FME coordinate system name of the feature into an attribute. |
Different coordinate system libraries (engines) not only contain coordinate system definitions, they also have unique reprojection algorithms. FME’s generic reprojection transformers, in the first table below, use CS-Map. A selection of other libraries is also available, some of which are specific to certain areas of the world or certain software platforms.
Default reprojections, as in a workspace with different input and output coordinate systems selected, are performed with the CS-Map library, also the equivalent of using the generic Reprojector transformer.
If you are reprojecting explicitly with a transformer in the workspace, using library-specific transformers is recommended. In the case of CsmapReprojector versus the Reprojector, the library is identical, but the CSMapReprojector handles vertical coordinate calculations whereas the Reprojector does not.
Library |
CS-Map |
CS-Map |
CS-Map |
Converts a given distance from one coordinate system to another. |
CS-Map |
CS-Map |
Library (External Links) |
Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII reprojection library. This library allows you to use the GridInQuestIIReprojector to transform coordinates between ETRS89 (WGS84) and the national coordinate systems of Great Britain, Northern Ireland and the Republic of Ireland. |
Sweden |
Reprojects attributes holding coordinate values from one coordinate system to another using the Gtrans reprojection library (from the National Land Survey of Sweden), and the specified translation file. |
Sweden |
Reprojects features from one coordinate system to another using the Gtrans reprojection library (from the National Land Survey of Sweden) and the specified translation file. |
Reprojects attributes from one coordinate system to another using the PROJ library. |
Switzerland |
Reprojects feature coordinates from one coordinate system to another using the REFRAME library. This transformer handles the usual planimetric and altimetric reference frame change for Switzerland. |
Features with reprojected attributes as specified in parameters. Geometry is unchanged.
Source Coordinate System |
Specify the coordinate system of the incoming features. Coordinate systems may be explicitly selected from the FME Coordinate System Gallery, or provided by name via an attribute value or user parameter. |
Specify the coordinate system to be reprojected to. Coordinate systems may be selected from the FME Coordinate System Gallery, or provided by name via an attribute value or user parameter. |
Transformation |
Select a method for applying a geographic transformation if one is needed to move between different datums:
Note: <Auto> and <None> are GUI only values. Use the alternative blank string and NULL_FME respectively when passing in as an attribute. |
Vertical Handling |
Select a method for handling Z values:
Geoid Height Grid |
If Vertical Handling includes an Orthometric height, specify the Geoid height grid file to be applied to the Z values. FME supports the following vertical grid formats:
The CsmapReprojector can apply grids in any of these formats via a .gdc file, which is a text file that list one or more grid files in the formats listed above. Grids will be tried in order until one is found that provides coverage for the point being transformed. Grid files may be listed with absolute paths, or by paths relative to the .gdc file. Example .gdc file contents for a grid file in the same folder as the .gdc: # comments start with '#' ./CGG2000.byn Some of the .gdc files shipped with FME reference grid files that are not included in the Desktop installer. Download additional Reprojection Grid Files at FME Downloads. See Vertical Grids for more information. |
X Attribute |
Provide the attribute containing the X coordinate to be reprojected. |
Y Attribute |
Provide the attribute containing the Y coordinate to be reprojected. |
Z Attribute |
If Vertical Handling is not set to Ignore Heights and leave them unchanged, provide the attribute containing the Z coordinate to be reprojected. |
Dialog Options - Tables
| Dependencies | Some reprojections may require additional grid files. |
Search for all results about the CsmapAttributeReprojector on the FME Community.
