GtransReprojector
Reprojects features from one coordinate system to another using the Gtrans reprojection library (from the National Land Survey of Sweden) and the specified translation file.
Dependencies
This transformer relies on Gtrans translation software which is included with FME on Windows platforms.
This is the translation file path.
Raster Parameters
If raster reprojection is required, a reverse translation file must also be supplied. This parameter defines the inverse translation file path.
Interpolation Type |
Select a method for interpolating reprojected cell values:
Cell Size |
Select a method for resizing cells:
Tolerance (cells) |
Sets the tolerance, in cells, for approximating reprojected cell locations. Using the default value of 0.0, every cell will be reprojected. If a value greater than 0.0 is specified, some cell locations will be approximated. The difference between an approximated cell location and the true cell location should be at most the tolerance value. For example, if a value of 0.5 is specified, each approximated cell location should be maximum one-half of a pixel away from its true location. Increasing the Tolerance value may improve performance. |
This transformer ignores the coordinate system set on input features, and does not tag output features with a coordinate system. If you want to take the output of the GtransReprojector transformer and write it to an output format that includes coordinate system metadata, you will need to specify which coordinate system to write, either by using a CoordinateSystemSetter transformer, or by setting the writer's Coordinate System parameter in the Workbench Navigator.
Dialog Options - Tables
Keywords: SWEREF99 "National Land Survey of Sweden" Sweden
