You are here: Reference Manual > FME Server Web Services > Transformation Services > Job Submitter Service > Examples
Example 1
A Job Submitter service request with one published parameters that specifies XML as the response format.
Request
http://localhost/fmejobsubmitter/Samples/austinDownload.fmw?THEMES=railroad&opt_responseformat=xml
Response
<?xml version="1.0" encoding="ISO-8859-1" ?>
<serviceResponse>
<!-- Service Status Info -->
<statusInfo>
<status>success</status>
<mode>sync</mode>
</statusInfo>
<!-- Service Return -->
<fmeTransformationResult>
<fmeEngineResponse>...</fmeEngineResponse>
<fmeServerResponse>...</fmeServerResponse>
</fmeTransformationResult>
<jobID>53</jobID>
</serviceResponse>
Example 2
A Job Submitter service request that specifies the service mode as async, requester’s e-mail address, and JSON as the response format.
Request
http://localhost/fmejobsubmitter/Samples/austinDownload.fmw?opt_servicemode=async&opt_requesteremail=joe@safe.com&opt_responseformat=xml
Response
{"serviceResponse": {
"email": "someone@safe.com",
"jobID": 15,
"statusInfo": {
"mode": "async",
"status": "success"
Example 3
Specifying the Notification Service topic to notify when a job succeeds or fails, respectively.
http://localhost/fmejobsubmitter/Samples/austinDownload.fmw?&nm_jobsuccess_topic=JOBSUBMITTER_ASYNC_JOB_SUCCESS&nm_jobfailure_topic=JOBSUBMITTER_ASYNC_JOB_FAILURE
See Also
