You are here: Administrator's Guide > Securing FME Server > Troubleshooting Active Directory Configurations > Single Sign-On Authentication Failure (Service Account)
Log file message:
(Single Sign-On) Failed authentication using pre-authenticated credentials (for a service account).
(Single Sign-On) Failed to create server credentials. Ensure that pre-authenticated credentials (for a service account) are correctly specified in single sign-on configuration.
Cause 1
The service account used by FME Server was not correctly specified. The account name or password may be incorrect, or both.
Resolution 1
Ensure that the service account details are correctly specified in the SSO Username and SSO Password fields of an Active Directory connection.
Cause 2
Authentication Method SASL is not specified, or the SASL Mechanism is not GSSAPI.
Resolution 2
SASL must be specified as the Authentication Method and GSSAPI must be specified as the SASL Mechanism in the Active Directory connection.
See Also
