Post-Configuration Scripts
After configuring the database, you must run additional post-configuration scripts to finish completing the installation. These scripts enable the installed services, sample workspaces, and notification subscribers.
- Ensure that FME Server is running. For more information, see:
- (PostgreSQL database only) On the machine on which the FME Server database server is installed, open
<PostgreSQLDir>\data\pg_hba.conf.- Change the following lines:
- Restart the FME Server Database service.
host all all 127.0.0.1/32 md5
host all all ::1/128 md5
to:
host all all 0.0.0.0/0 md5
host all all ::/0 md5
- Run the following scripts:
- Windows:
- Linux:
- <FMEServerDir>/Clients/utilities/addQueueNode.sh
- <FMEServerDir>/Clients/utilities/addPublishers.sh
- Either of the following:
- <FMEServerDir>/Clients/utilities/configureDemoWorkspaces.sh
- <FMEServerDir>/Clients/utilities/addServices.sh
OR
- <FMEServerDir>/Clients/utilities/addSubscribers.sh
- <FMEServerDir>/Clients/utilities/addCleanupTasks.sh
- Restart the FME Server Core and FME Server Engines System Services.
On all machines on which the FME Server Core is installed, open <FMEServerDir>\Utilities\, and run runPostInstall.bat.
Note: You may need to run this script as administrator (right-click and select Run as administrator).
On all machines on which the FME Server Core is installed, in the following order:
