Schema (From Table) Quick Facts
Format Type Identifier | SCHEMAFROMTABLE |
Reader/Writer | Reader |
Licensing Level | Base |
Dependencies | None |
Dataset Type | Reader: File, Folder, URL, or database name |
Feature Type | schema |
Typical File Extensions | Depends on reader |
Automated Translation Support | Yes |
User-Defined Attributes | No |
Coordinate System Support | No |
Generic Color Support | No |
Spatial Index | No |
Schema Required | No |
Transaction Support | No |
Encoding Support | No |
Geometry Type | fme_type |
Schema (From Table) Geometry Support
In all cases, the geometry is passed untouched to the writer chosen at runtime, which may or may not support all geometry types.
Geometry |
Supported? |
aggregate | not applicable |
circles | not applicable |
circular arc | not applicable |
donut polygon | not applicable |
elliptical arc | not applicable |
ellipses | not applicable |
line | not applicable |
none | not applicable |
point | not applicable |
raster | not applicable |
solid | not applicable |
surface | not applicable |
text | not applicable |
z values | not applicable |
