Schema (From Table) Feature Representation
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
Schema (From Table) features have no geometry.
The following schema information is added to features:
  • Feature type name
  • Attribute names
  • Attribute's native data type
  • Attribute's fme_data_type
  • Feature type's geometry
  • Feature type's coordinate system (only if the real reader provides coordinate system via schema features)
The table below further specifies these attributes and their allowed values.
Attribute Name
Contents
fme_feature_type_name
Name of the source feature type
No default
attribute{#}.name
A list attribute that stores the all the attribute names for the feature type defined in "fme_feature_type_name" attribute.
No default
attribute{#}.native_data_type
A list attribute that stores the type information that corresponds to the source format
No default
attribute{#}.fme_data_type
A list attribute that stores the type information that FME uses (obtained from mapping the native types to fme types)
No default
fme_geometry{#} A list attribute that stores all the supported geometries for the feature type defined in "fme_feature_type_name" attribute
fme_format_short_name
Short name for the source format
No default
fme_format_long_name
Long descriptive name for the source format
No default
fme_coordinate_system
Feature type's coordinate system name. Only supported for readers that provide coordinate system information on schema features.
No default
