OpenStreetMap (OSM) Protocolbuffer Binary Format (PBF) Reader Parameters
Advanced
Schema Attributes
Use Search Envelope
Using the minimum and maximum x and y parameters, define a bounding box that will be used to filter the input features. Only features that intersect with the bounding box are returned.
If all four coordinates of the search envelope are specified as 0, the search envelope will be disabled.
