• Workbench Format Resources
    • FME Terminology
    • FME Geometry Model
    • Feature Types
    • Using Database Connections
    • Using Web Service Connections
    • About FME Rasters
    • Standard FME Date and Time Format
  • All Formats
    • List of Supported Formats
  • Popular Formats
    • Quick Facts: Popular Formats
    • Bentley MicroStation Design Reader/Writer
    • Autodesk AutoCAD DWG/DXF Reader/Writer
    • CSV (Comma-Separated Value) Reader/Writer
    • Esri Shapefile Reader/Writer
    • Esri Geodatabase Reader/Writer
    • FME Feature Store Reader/Writer
    • Google KML Reader/Writer
    • MapInfo TAB (MAPINFO/MITAB) Reader/Writer
    • Microsoft Excel (XLSXR/XLSXW) Reader/Writer
    • TIFF (Tagged Image File Format) Reader/Writer
    • XML (Extensible Markup Language) Reader/Writer
  • Transformers
    • Transformer Resources
  • New formats for 2018
    • Bentley i-model Interchange Format Reader
    • Continuous Acquisition and Life-Cycle Support (CALS) Reader
    • FME Augmented Reality (AR) Writer
    • GDAL Generic Raster Reader
    • Google Cloud Spanner Reader/Writer
    • HERE Venue Map (GML) Reader
    • HYPACK Border Reader/Writer
    • IDRISI Raster (RST) Reader/Writer
    • LDAP/Active Directory Reader (Technology Preview)
    • Microsoft PowerPoint Writer
    • Microsoft Word Writer
    • PCD (Point Cloud Data) Reader/Writer
    • QVX (QlikView Data Exchange) Writer
    • SOSI GML Reader/Writer
    • Well Logging Ascii Standard Format (WLAS) Reader
  • All Files
    • Design File Quick Facts
    • V7 Reader Parameters
    • V8 Reader Parameters
    • V7 Writer Parameters
    • V8 Writer Parameters
    • Writing Levels in V8 (DEF Line Parameters)
    • Feature Representation
      • Attribute Linkages
        • Attribute Lists – all linkages
          • Example
        • Attribute Lists – string linkage
        • Attribute Lists – user linkage
        • User Linkages – userId of 22234 and 39030 (Extended entity data linkage)
        • Attribute Lists – dbase, odbc, oracle, ris, dmrs, informix linkages
        • Attribute Lists – framme linkage
        • Attribute Lists – incosada linkage
        • Custom Line Styles
        • XAttribute Attributes
        • Attribute Lists – XFM Linkages
        • Attribute Lists – XFM XAttributes
      • Arcs
      • Cells
      • Cells (Shared)
      • Complex Shapes Strings
      • Curves
      • BSpline Curves
      • External Reference Files
      • Multilines
      • Dimensions
      • Ellipses
      • Lines
      • Non-Geometric Collections
      • Points
      • Polygon Collections
      • Shapes
      • Solids
      • 3D Solids
      • Tags
      • Multi-text Strings
      • Text Nodes
      • Text Strings
      • XFM Feature Stores
You are here: Popular Formats > Bentley MicroStation Design Reader/Writer > Feature Representation > Attribute Linkages > XAttribute Attributes
Each element in a Design file may have one or more Xattribute attributes attached to it.
Because an element may have more than one XAttribute, these attributes are stored in an FME feature attribute list named igds_xattributes{#}. As with other feature attribute lists, # starts at zero and increments for each successive linkage.
