Attribute Lists – framme linkage
If the linkage is a framme type, the following attribute list item names are used to specify the values for the Facilities Rulebase Application Model Management Environment (FRAMME) linkage.
Familiarity with the FRAMME system is necessary to fully understand the meaning of these attributes. Note that FRAMME linkages for Version 8 DGN files are only supported for reading.
Linkage Parameter |
Contents |
ufid |
The unique feature ID of the linkage. This is part of the database key used by FRAMME. Range: unsigned 32-bit integer Default: 0 |
| ufid_low |
The low order bytes of the unique feature ID of the linkage. This is part of the database key used by FRAMME. Range: unsigned 16-bit integer Default: 0 |
| ufid_high |
The high order bytes of the unique feature ID of the linkage. This is part of the database key used by FRAMME. Range: unsigned 16-bit integer Default: 0 |
design_file |
The base name of the design file holding the linkage. This makes up the second part of the database key used by FRAMME. Range: character string Default: No default – not used when writing |
state_num |
The state number of the FRAMME feature Range: unsigned 16-bit integer Default: 0 |
rule_base_id |
The FRAMME rule base identifier which is fixed at 0x20. Range: 0x20 (32 decimal) Default: 0x20 |
component_num |
The component number of the FRAMME feature. Range: unsigned 16-bit integer Default: 0 |
component_count |
The component count, or occurrence, of the FRAMME feature. Range: unsigned 16-bit integer Default: 0 |
feature_num |
The feature number of the FRAMME feature. Range: unsigned 16-bit integer Default: 0 |
long{#} |
A list of 16-bit words that associated with "long" FRAMME linkages. Range: unsigned 16-bit integer Default: 0 |
For convenience, some of the list item names above are provided as non-list attributes which represent only the first framme linkage found per element. These attributes are listed below.
Linkage Parameter |
Contents |
| ufid |
| ufid_low |
| ufid_high |
| dgnfile |
| state_num |
| comp_num |
| comp_count |
| feat_num |
