Hierarchical Data Format 4 (HDF4 ASTER) Quick Facts
About Quick Facts Tables
Format Type Identifier
HDF4_ASTER
Reader/Writer
Reader
Licensing Level
Professional and above
Dependencies
None
Dataset Type
Reader: File
Feature Type
HDF4_ASTER, <source_dataset_filename>, <subdataset_name>, or <source_dataset_filename_subdataset_name>
Typical File Extensions
.hdf
Automated Translation Support
No
User-Defined Attributes
Through TAB files
Coordinate System Support
Yes
Generic Color Support
No
Spatial Index
Never
Schema Required
No
Transaction Support
No
Encoding Support
No
Geometry Type
hdf4_aster_type
Hierarchical Data Format 4 (HDF4 ASTER) Geometry Support
Geometry
Supported?
aggregate
no
circles
no
circular arc
no
donut polygon
no
elliptical arc
no
ellipses
no
line
no
none
no
point
no
polygon
no
raster
yes
solid
no
surface
no
text
no
z values
no
Hierarchical Data Format 4 (HDF4 ASTER) Raster Support
Band Interpretations
UInt8, UInt16, Int32, Real32, Real64
Palette Key Interpretations
UInt8
Palette Value Interpretations
RGB24, RGBA32
Nodata Value
none
Cell Origin (x, y)
0.5, 0.5
Rotation Support
Yes
GCP Support
Yes
World File Support
No
TAB File Support
Yes
