Hierarchical Data Format 4 (HDF4 ASTER) Feature Representation
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
Each ASTER (HDF4) raster image subdataset corresponds to a single feature in FME.
Attribute Name
Contents
hdf4_aster_type
This will always be hdf4_raster.
hdf4_aster_asterobservatiomode
Observation modes for each sensorgroup.
hdf4_aster_asteroperationmode
One of three operation modes (OBSERVATION, CALIBRATION or TEST).
hdf4_aster_astersceneid
The scene identifier defined by path, row and view.
hdf4_aster_averageoffset
Average offset value (LAOset, PAOset) where LAOset is the average offset in along track direction, and PAOset is the average offset in cross track direction.
hdf4_aster_avgcorrelcoef
The average correlation coefficient.
hdf4_aster_calendardate
The year (and optionally month and day). This attribute is used to specify a single date covered by a data collection, granule or event.
hdf4_aster_coarsedemversion
The version information of the coarse DEM database (version, issuance date, comments).
hdf4_aster_conunit{}
See product specifications.
hdf4_aster_conunit{}b
hdf4_aster_conunit{}n
hdf4_aster_corintel{}
Correction of the intertelescope error of SWIR and TIR.
hdf4_aster_corintel{}b
hdf4_aster_corintel{}n
hdf4_aster_corpara{}
Correction of the SWIR parallax error.
hdf4_aster_corpara{}b
hdf4_aster_corpara{}n
hdf4_aster_cthld
hdf4_aster_eastboundingcoordinate
Eastern-most coordinate of the limit of coverage expressed in longitude.
hdf4_aster_flyingdirection
The satellite flight direction when observation is done. ‘AS’: ascending direction, ‘DE’: descending direction.
hdf4_aster_futurereviewdate
Date of next planned QA peer review.
hdf4_aster_gain
Band number and gain setting.
hdf4_aster_geometricdbversion
The version information of the geometric correction data (version, issuance date).
hdf4_aster_hdfeosversion
hdf4_aster_idofastergdsdatabrowse
hdf4_aster_idofastergdsdatagranule
Unique identifier for location of a data granule held in ASTER GDS.
hdf4_aster_imagedatainformation{}
hdf4_aster_imagedatainformation{}b
hdf4_aster_imagedatainformation{}n
hdf4_aster_incl{}
hdf4_aster_incl{}b
hdf4_aster_incl{}n
hdf4_aster_instrumentshortname
The unique identifier of an instrument (ASTER).
hdf4_aster_lowerleft
The coordinates of the lower-left corner of the scene (lat/long).
hdf4_aster_lowerright
The coordinates of the lower-right corner of the scene (lat/long).
hdf4_aster_maporientationangle
The angle of the clockwise rotation from Y-axis of the map projected coordinates at ascending, within the range [-90.0, 90.0].
hdf4_aster_mapprojectionname
The name of the systematic representation of all or part of the surface of the Earth on a plane or developable surface.
hdf4_aster_meanandstd{}
hdf4_aster_meanandstd{}b
hdf4_aster_meanandstd{}n
hdf4_aster_measurementpointnumber{}
The number of measurement points.
hdf4_aster_minandmax{}
hdf4_aster_minandmax{}b
hdf4_aster_minandmax{}n
hdf4_aster_modeandmedian{}
hdf4_aster_modeandmedian{}b
hdf4_aster_modeandmedian{}n
hdf4_aster_mpmethod{}
Map projection method (UTM, PS, LAMCC, SOM or EQRECT).
hdf4_aster_mpmethod{}b
hdf4_aster_mpmethod{}n
hdf4_aster_northboundingcoordinate
Northern-most limit of coverage expressed in geodetic latitude.
hdf4_aster_numberofbadpixels{}
The number of bad pixels in the L1B band images.
hdf4_aster_numberofbadpixels{}b
The number of bad pixels in the L1B band 3n image.
hdf4_aster_numberofbadpixels{}n
The number of bad pixels in the L1B band 3b image.
hdf4_aster_numberofmeasurements{}
The number of measurements.
hdf4_aster_offset{}
hdf4_aster_offset{}b
hdf4_aster_offset{}n
hdf4_aster_orbitnumber
The orbit number of the satellite, when data is acquired (path, row, view).
hdf4_aster_pctimagematch
hdf4_aster_pgeversion
Version of PGE, updated whenever code or any static is input in the delivered algorithm package.
hdf4_aster_platformshohdf4_aster_
rtname
hdf4_aster_pointingangle
Pointing angle for the corresponding sensor.
hdf4_aster_processedbands
Observation modes for each sensorgroup (VNIR1, VNIR2, SWIR or TIR). A string indicating which bands were processed. Processed bands are indicated by a band number. ‘XX’ is used to mark bands which were NOT processed.
hdf4_aster_processingcenter
Name of the facility where the granule was processed.
hdf4_aster_processingflag{}
Processing flag. 0: no output, 1: output is the result computed, 2: output is extracted from registration file, 4: output obtained by other method.
hdf4_aster_processinglevelid
This attribute reflects the classification of the science data processing level, which defines in general terms the characteristics of the output of the processing performed.
hdf4_aster_productiondatetime
hdf4_aster_projectionparameters{}
Parameters used in GCTP map projection.
hdf4_aster_projectionparameters{}b
hdf4_aster_projectionparameters{}n
hdf4_aster_qapercentinterpolateddata
Granule level percent interpolated data.
hdf4_aster_qapercentmissingdata
Granule level percent missing data.
hdf4_aster_qapercentoutofboundsdata
Granule level percent out of bounds data.
hdf4_aster_qadrantcloudcoverage
Cloud coverage in percent for each of the four quarters of the scene (upper left, upper right, lower left, lower right).
hdf4_aster_radiometricdbversion
The version information of the radiometric correction data (version, issuance date).
hdf4_aster_receivingcenter
“EODS”, fixed value.
hdf4_aster_recurrentcyclenumber
The satellite recurrent cycle number and the revolution number in the cycle.
hdf4_aster_reprocessingactual
Granule level, stating what reprocessing has been performed on this granule.
hdf4_aster_resmethod{}
Resampling method. ‘BL’ or ‘NN’ or ‘CC’.
hdf4_aster_resmethod{}b
hdf4_aster_resmethod{}n
hdf4_aster_scenecenter
Longitude and latitude of the scene center (lat, long).
hdf4_aster_scenecloudcoverage
Cloud coverage in percent for the whole scene.
hdf4_aster_sciencereviewdate
Date of last QA peer review.
hdf4_aster_sensorname
VNIR, SWIR or TIR.
hdf4_aster_sensorshortname
Sensor short name.
hdf4_aster_settingtimeofpointing
Date and time that the pointing was performed.
hdf4_aster_shortname
The official reference name used in identifying the contents of the data collection.
hdf4_aster_sizembdatagranule
The size attribute will indicate the volume of data contained in the granule.
hdf4_aster_solardirection
The sun direction as seen from the scene center.
hdf4_aster_sourcedataproduct
Information about the input data used to generate the L1B product.
hdf4_aster_southboundingcorrdinate
Southern-most limit of coverage expressed in geodetic latitude.
hdf4_aster_spatialresolution
The nominal spatial resolutions of VNIR, SWIR and TIR.
hdf4_aster_standarddeviationoffset
Standard deviation offset value (LSDOset, PSDOset) where LSDOset is the standard deviation offset in the along track direction and PSDOset is the standard deviation offset in the cross track direction.
hdf4_aster_threshold{}
Threshold value (CThld, LOThld, POThld, VOThld) where CThld is the correction threshold, LOThld is the offset threshold in the along track direction, POThld is the offset threshold in the cross track direction and VOThld is the vector offset threshold.
hdf4_aster_timeofday
The hour (and optionally minute and second) of the day. This attribute is used to specify a single point in time covered by a data collection, granule or event.
hdf4_aster_upperleft
The coordinates of the upper-left corner of the scene (lat/long).
hdf4_aster_upperright
The coordinates of the upper-right corner of the scene (lat/long).
hdf4_aster_utmzonecode{}
The zone code for utm projection.
hdf4_aster_utmzonecode{}b
hdf4_aster_utmzonecode{}n
hdf4_aster_westboundingcoordinate
Pointing angle for the corresponding sensor band number and gain setting western-most coordinate of the limit of cloud coverage expressed in longitude.
hdf4_aster_subdataset_name
When this is present on a feature, the feature is a subdataset. This attribute shows the name of the subdataset.
hdf4_aster_subdataset_description
When this is present on a feature, the feature is a subdataset. This attribute gives a description of the subdataset.
