Esri ArcGIS Layer Quick Facts
About Quick Facts Tables
Format Type Identifier
ARCGIS_LAYER
Reader/Writer
Reader
Licensing Level
Esri Edition
Dependencies
Esri ArcGIS
The bit version (32-bit or 64-bit) must be the same for FME and ArcGIS.
Dataset Type
Esri Layer/Feature Class
Feature Type
Typical File Extensions
  • Esri Layer: .lyr
  • Esri Layer Package: .lpk
  • Esri Feature Class: none. The “path” to the feature class is used.
Automated Translation Support
Yes
User-Defined Attributes
Yes
Coordinate System Support
Yes
Generic Color Support
Yes
Spatial Index
Optional
Schema Required
Not applicable
Transaction Support
Not applicable
Geometry Type
geodb_type
Encoding Support No
Esri ArcGIS Layer Geometry Support
Geometry
Supported?
aggregate
yes
circles
yes
circular arc
yes
donut polygon
yes
elliptical arc
yes
ellipses
yes
line
yes
none
yes
point
yes
polygon
yes
raster
no
solid
no
surface
no
text
yes
z values
yes
