Feature Representation
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
The ArcGIS Layer modules make use of the following special attribute names.
Attribute Name
Contents
geodb_type
The type of geometric entity stored within the feature. The valid values are listed below:
geodb_point
geodb_multipoint
geodb_polyline
geodb_arc
geodb_ellipse
geodb_polygon
geodb_annotation
geodb_dimension
geodb_simple_junction
geodb_simple_edge
geodb_complex_junction
geodb_complex_edge
For a description of the attributes belonging to each of the different geodb_type’s, please see the chapter Esri Geodatabase Reader/Writer.
geodb_feature_is_simple
Indicates whether or not the geometry is simple.
Features read from a dataset also have an attribute for each attribute in the layer/feature class.
