KML Writer Feature Type: User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name The name of the column to be written.
Type
The type of a column in a table. The valid values for the column type are listed below:
kml_boolean
kml_buffer
kml_char
kml_date
kml_datetime
kml_int16
kml_int32
kml_real32
kml_real64
kml_time
