RasterResampler
Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, by interpolating new cell values.
- Reducing raster resolution (by reducing the number of cells and increasing cell size)
- Coercing a raster to specific dimensions or cell (pixel) size for further processing purposes or to match other data
- Creating thumbnail images of rasters
The RasterResampler accepts raster features and alters the number of rows/columns and resizes cell (pixel) size according to the parameter selections. One raster feature is output for each input feature.
Output raster resolution may be specified by set dimensions (columns and rows), cell size in ground units, or percentage of original resolution.
A variety of methods are available for output cell value interpolation.
A: Original resolution
B: Desired resolution
C: Desired resolution compared to original
D: Resampled output raster
In this example, we will resample an orthophoto. The original raster is 1600 x 1000 pixels, with a cell size (Cell Spacing) of 1,1 - one meter wide by one meter high (the ground units of the projection).
The raster is routed into a RasterResampler.
In the parameters dialog, we select the Resolution Specification of Cell Spacing. This enables the X and Y Cell Spacing parameters, which are then both set to 25 - meaning 25 meters in ground units.
Interpolation Type is left as the default of Nearest Neighbor.
The output raster covers the same geographic extents as the input, but the cells are now 25 meters square and the resolution has correspondingly decreased to 64 x 40.
- To resize rasters (clipping or padding) without changing the cell size, consider using the RasterSubsetter
- To resample rasters to multiple sizes, consider using the WebMapTiler or the RasterPyramider.
- To split rasters in multiple smaller rasters without changing the cell size, consider using the RasterTiler.
- Although this transformer can be used to increase raster resolution, usually there is little benefit in doing so (with an exception being to match the resolution of other raster data for processing purposes).
Choosing a Raster Transformer
Working with Rasters
RasterCellOriginSetter | Sets the cell origin point within cells in a raster. |
RasterConvolver |
RasterExpressionEvaluator | Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements. |
RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster. |
RasterGCPExtractor | Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes. |
RasterGCPSetter | Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates. |
RasterGeoreferencer | Georeferences a raster by either known corner coordinates or origin, cell size, and rotation. |
RasterHillshader | Generates a grayscale shaded relief representation of terrain, based on elevation values. |
RasterInterpretationCoercer |
RasterMosaicker | Merges multiple raster features into a single raster feature. |
RasterPropertyExtractor | Extracts the geometry properties of a raster feature and exposes them as attributes. |
RasterPyramider | Resamples rasters to multiple resolutions, based on either number of levels or dimensions of the smallest output raster. |
RasterRegisterer | Transforms an image to minimize its difference with another. |
RasterResampler | Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, and interpolates new cell values. |
RasterRotationApplier |
RasterSharpener | Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
RasterSubsetter | Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter. |
RasterTiler | Splits each input raster into a series of tiles by specifying either a tile size in cells/pixels or the number of tiles. |
RasterToPolygonCoercer | Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster. |
WebMapTiler | Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles. |
Working with Bands
RasterBandAdder | Adds a new band to a raster feature. |
RasterBandCombiner | Merges coincidental raster features into a single output raster feature, preserving and appending all bands. |
RasterBandInterpretationCoercer |
RasterBandKeeper |
RasterBandMinMaxExtractor | Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute. |
RasterBandNameSetter | Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers. |
RasterBandNodataRemover | Removes the existing nodata identifier from selected bands of a raster feature. Any values previously equal to the nodata value are considered valid data. |
RasterBandNodataSetter | Sets a new nodata value on selected bands of a raster feature. |
RasterBandOrderer | Specifies the required order of bands in a raster. Bands are reordered according to the input band indices. |
RasterBandPropertyExtractor | Extracts the band and palette properties of a raster feature and exposes them as attributes. |
RasterBandRemover | Removes any selected bands from a raster feature. |
RasterBandSeparator | Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations. |
RasterStatisticsCalculator | Calculates statistics on raster bands and adds the results as attributes. |
Working with Cells
RasterAspectCalculator |
RasterCellCoercer | Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes. |
RasterCellValueCalculator | Evaluates basic arithmetic , minimum, maximum or average operations on the cell values of a pair of rasters. |
RasterCellValueReplacer | Replaces a range of band values in a raster with a new single value. |
RasterCellValueRounder | Rounds off raster cell values. |
RasterSegmenter | Partitions a raster image into arbitrarily sized groups of cells from the input image based on intensity differences in the input raster image cells. |
RasterSingularCellValueCalculator | Performs basic arithmetic operations on the cell values of a raster against a numeric value. |
RasterSlopeCalculator | Calculates the slope (maximum rate of change in z) for each cell of a raster. |
Working with Palettes
RasterPaletteAdder |
RasterPaletteExtractor | Creates a string representation of an existing palette on a raster and saves it to an attribute. |
RasterPaletteGenerator | Generates a palette out of the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette. |
RasterPaletteInterpretationCoercer |
RasterPaletteNodataSetter |
RasterPaletteRemover | Removes selected palette(s) from raster features. |
RasterPaletteResolver | Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands. |
Workflow Control
RasterCheckpointer | Forces accumulated raster operations to be processed, saving the state to disk and releasing resources to tune performance or assist with memory limitations. |
RasterConsumer | Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features. |
RasterExtractor | Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats. |
RasterNumericCreator | Creates a numeric raster of specified size and resolution, with default cell values. |
RasterReplacer | Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster. |
RasterRGBCreator | Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values. |
RasterSelector |
Vectors and Rasters
ImageRasterizer | Creates a raster representation of vector or point cloud input features, using the fme_color attribute over a solid background fill for vector features. Point clouds may be rendered using their color or intensity components. |
NumericRasterizer | Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background. |
MapnikRasterizer | Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit. |
PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
PointOnRasterValueExtractor | Extracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the feature. |
RasterDEMGenerator | Produces a raster digital elevation model (DEM) by uniformly sampling a Delaunay triangulation generated from input points and breaklines. |
VectorOnRasterOverlayer | Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components. |
One resampled raster per input raster feature.
INVALID_RASTER_NO_BANDS
INVALID_PARAMETER_NUMBER_OF_ROWS
Resolution Specification |
Select a method for specifying output raster size. Options include:
Number of Columns (cells) | If Resolution Specification is Rows and Columns, specify the desired raster width in cells (pixels). | ||||||
Number of Rows (cells) | If Resolution Specification is Rows and Columns, specify the desired raster height in cells (pixels). | ||||||
X Cell Spacing | If Resolution Specification is Cell Spacing, specify the desired cell (pixel) width in ground units. | ||||||
Y Cell Spacing | If Resolution Specification is Cell Spacing, specify the desired cell (pixel) height in ground units. | ||||||
Percentage |
If Resolution Specification is Percentage, specify the desired percentage. This number must be greater than 0, and may be greater than or less than 100. 100 is equal to the input size. |
Interpolation Type |
Cell values are interpolated to produce various raster sizes and resolutions. Choose a method:
Dialog Options - Tables
Dependencies | None |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History |
Search for all results about the RasterResampler on the FME Community.
