RasterExtractor
Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats.
- Storing rasters in databases that do not support specific raster types but do support Blobs.
- Storing a raster as an attribute of a feature, such as attaching images to vector features.
The RasterExtractor receives raster features and puts a copy of the raster geometry into an attribute, as a Blob - a Binary Large OBject.
The Blob content may be encoded as a variety of common raster formats. The name of the chosen format will also be recorded in an attribute for reference when decoding.
There are no parameters in the transformer to control how the raster is formatted, and encoding is done based on default settings for the chosen format. If necessary, format-specific settings may be overwritten by setting format attributes on the raster feature, prior using the RasterExtractor. For example, if encoding to JPEG, the compression level could be set via the jpeg_compression_level format attribute. Consult the appropriate format’s Writer documentation for a complete list of available attributes.
In this example, we will prepare and write a raster to a Microsoft SQL Server Non-Spatial database, which does not support geometry of any form as an attribute type.
The raster feature is routed into a RasterExtractor, and then on to a Microsoft SQL Server Non-Spatial Writer.
In the parameters dialog, Format is set to GeoTiff, and the Format Name and Blob attributes are left with the default names applied.
Examining the output from the RasterExtractor in the FME Data Inspector, note that the feature has two new attributes - _rasterBlob, containing the encoded raster, and _rasterFormatName, containing the name (GeoTIFF) of the chosen encoding.
In the writer parameters, User Attributes, the Type of _rasterBlob is adjusted to Image, which is a binary field that supports larger values than varbinary, ensuring the data will not be truncated. (Note that the appropriate data type may vary between database formats.)
- This transformer may be used for writing raster data to a database field. Note that when writing the Raster Blob Attribute, you may need to adjust the attribute type to an unbounded data type to avoid truncation of the data. Choose an appropriate attribute type depending on the destination format (for example, an appropriate attribute type for SQL Server is 'image').
- The RasterReplacer may be used to perform the reverse operation and convert the encoded blob back to the original raster geometry.
- Different encoding formats may carry through different information. For example, GeoTIFF preserves coordinate system and extents, whereas PNG does not.
- To carry out a similar operation on vector data, use the GeometryExtractor transformer. For point cloud data, use the PointCloudExtractor.
- To remove the original geometry after using a RasterExtractor (leaving only the Blob attribute version), use a GeometryRemover.
- The AttributeFileWriter transformer can be used to write the Raster Blob Attribute directly to a file.
Choosing a Raster Transformer
Working with Rasters
RasterCellOriginSetter | Sets the cell origin point within cells in a raster. |
RasterConvolver |
RasterExpressionEvaluator | Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements. |
RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster. |
RasterGCPExtractor | Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes. |
RasterGCPSetter | Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates. |
RasterGeoreferencer | Georeferences a raster by either known corner coordinates or origin, cell size, and rotation. |
RasterHillshader | Generates a grayscale shaded relief representation of terrain, based on elevation values. |
RasterInterpretationCoercer |
RasterMosaicker | Merges multiple raster features into a single raster feature. |
RasterPropertyExtractor | Extracts the geometry properties of a raster feature and exposes them as attributes. |
RasterPyramider | Resamples rasters to multiple resolutions, based on either number of levels or dimensions of the smallest output raster. |
RasterRegisterer | Transforms an image to minimize its difference with another. |
RasterResampler | Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, and interpolates new cell values. |
RasterRotationApplier |
RasterSharpener | Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
RasterSubsetter | Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter. |
RasterTiler | Splits each input raster into a series of tiles by specifying either a tile size in cells/pixels or the number of tiles. |
RasterToPolygonCoercer | Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster. |
WebMapTiler | Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles. |
Working with Bands
RasterBandAdder | Adds a new band to a raster feature. |
RasterBandCombiner | Merges coincidental raster features into a single output raster feature, preserving and appending all bands. |
RasterBandInterpretationCoercer |
RasterBandKeeper |
RasterBandMinMaxExtractor | Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute. |
RasterBandNameSetter | Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers. |
RasterBandNodataRemover | Removes the existing nodata identifier from selected bands of a raster feature. Any values previously equal to the nodata value are considered valid data. |
RasterBandNodataSetter | Sets a new nodata value on selected bands of a raster feature. |
RasterBandOrderer | Specifies the required order of bands in a raster. Bands are reordered according to the input band indices. |
RasterBandPropertyExtractor | Extracts the band and palette properties of a raster feature and exposes them as attributes. |
RasterBandRemover | Removes any selected bands from a raster feature. |
RasterBandSeparator | Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations. |
RasterStatisticsCalculator | Calculates statistics on raster bands and adds the results as attributes. |
Working with Cells
RasterAspectCalculator |
RasterCellCoercer | Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes. |
RasterCellValueCalculator | Evaluates basic arithmetic , minimum, maximum or average operations on the cell values of a pair of rasters. |
RasterCellValueReplacer | Replaces a range of band values in a raster with a new single value. |
RasterCellValueRounder | Rounds off raster cell values. |
RasterSegmenter | Partitions a raster image into arbitrarily sized groups of cells from the input image based on intensity differences in the input raster image cells. |
RasterSingularCellValueCalculator | Performs basic arithmetic operations on the cell values of a raster against a numeric value. |
RasterSlopeCalculator | Calculates the slope (maximum rate of change in z) for each cell of a raster. |
Working with Palettes
RasterPaletteAdder |
RasterPaletteExtractor | Creates a string representation of an existing palette on a raster and saves it to an attribute. |
RasterPaletteGenerator | Generates a palette out of the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette. |
RasterPaletteInterpretationCoercer |
RasterPaletteNodataSetter |
RasterPaletteRemover | Removes selected palette(s) from raster features. |
RasterPaletteResolver | Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands. |
Workflow Control
RasterCheckpointer | Forces accumulated raster operations to be processed, saving the state to disk and releasing resources to tune performance or assist with memory limitations. |
RasterConsumer | Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features. |
RasterExtractor | Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats. |
RasterNumericCreator | Creates a numeric raster of specified size and resolution, with default cell values. |
RasterReplacer | Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster. |
RasterRGBCreator | Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values. |
RasterSelector |
Vectors and Rasters
ImageRasterizer | Creates a raster representation of vector or point cloud input features, using the fme_color attribute over a solid background fill for vector features. Point clouds may be rendered using their color or intensity components. |
NumericRasterizer | Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background. |
MapnikRasterizer | Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit. |
PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
PointOnRasterValueExtractor | Extracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the feature. |
RasterDEMGenerator | Produces a raster digital elevation model (DEM) by uniformly sampling a Delaunay triangulation generated from input points and breaklines. |
VectorOnRasterOverlayer | Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components. |
Raster features with their geometry also encoded as an attribute as specified.
INVALID_FEATURE_CANNOT_WRITE
Format |
The raster format used to encode the blob. Choices include:
Format Name Attribute | Name the attribute to contain the selected Format name. |
Blob Attribute | Name the attribute to contain the encoded Blob. |
Dialog Options - Tables
Dependencies | None |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History |
Search for all results about the RasterExtractor on the FME Community.
