RasterInterpretationCoercer
Alters the interpretation type of rasters, including all bands, and converts cell values if necessary.
- Changing raster interpretation type to meet format or processing requirements.
The RasterInterpretationCoercer receives raster features and converts all bands based on a chosen Destination Interpretation Type. Choices include:
- RGB24
- RGBA32
- RGB48
- RGBA64
- Gray8
- Gray16
- Red8
- Red16
- Green8
- Green16
- Blue8
- Blue16
- Alpha8
- Alpha16
- UInt8
- Int8
- UInt16
- Int16
- UInt32
- Int32
- UInt64
- Int64
- Real32
- Real64
Options are available to control the manner in which cell values are converted, handling color to color, numeric to color, color to numeric, numeric to numeric, and floating-point to integer conversions.
Band names, if they exist, are retained.
Multi-Band Rasters
When converting to an interpretation with multiple components, such as RGB and RGBA, the input raster will be expected to have exactly 1, 3, or 4 bands. If only one band is supplied, it will be cloned to create the correct number of bands for conversion to the chosen interpretation.
When converting to a single color or numeric interpretation, multiple input bands will be averaged into a single one.
Palettes
If bands selected for conversion contain palettes, the destination interpretation must be an unsigned integer - UInt8, UInt16 or UInt32 to accommodate the palette keys.
In this example, we want to reduce the bit depth and add an alpha band to our original raster, an RGB48 image that has three 16-bit bands - red, green, and blue.
Note the individual cell values for the three bands, which fall in the range of 0 to 65535 (the possible values for a 16-bit band).
The raster is routed into a RasterInterpretationCoercer.
In the parameters dialog, we select a Destination Interpretation of RGBA32.
This choice enables a number of Conversion Options. The transformer is not aware of what type of values it may need to convert, and so provides options for all variations - color, numeric, and float.
For our RGB input raster, the important ones are:
- RGB to RGBA: Create opaque alpha band. This will add an alpha band, and all cells in the band will have the maximum value for the selected bit depth - in this case, 255, as we are converting to 8-bit bands.
The input raster does not have nodata values, and so we cannot create an alpha band from them. - Convert from Color to Color: Scale by data type. Values will be scaled according to the ranges of both the input and output rasters. As we are converting from 16-bit to 8-bit, this means that:
- 0 will become 0
- 65535 (the maximum 16-bit value) becomes 255 (the maximum 8-bit value)
- Values in between are scaled accordingly.
The output raster feature has four bands, including the new alpha band, and all are 8-bit.
The individual cell values have been scaled, and the alpha values are set to 255 (fully opaque).
Note that reducing bit depth may result in a loss of precision. Conversely, increasing bit depth will not increase image quality.
- The RasterBandInterpretationCoercer performs similar conversions on individual bands.
- The RasterPaletteInterpretationCoercer performs similar conversions on palettes.
Choosing a Raster Transformer
Working with Rasters
RasterCellOriginSetter | Sets the cell origin point within cells in a raster. |
RasterConvolver |
RasterExpressionEvaluator | Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements. |
RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster. |
RasterGCPExtractor | Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes. |
RasterGCPSetter | Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates. |
RasterGeoreferencer | Georeferences a raster by either known corner coordinates or origin, cell size, and rotation. |
RasterHillshader | Generates a grayscale shaded relief representation of terrain, based on elevation values. |
RasterInterpretationCoercer |
RasterMosaicker | Merges multiple raster features into a single raster feature. |
RasterPropertyExtractor | Extracts the geometry properties of a raster feature and exposes them as attributes. |
RasterPyramider | Resamples rasters to multiple resolutions, based on either number of levels or dimensions of the smallest output raster. |
RasterRegisterer | Transforms an image to minimize its difference with another. |
RasterResampler | Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, and interpolates new cell values. |
RasterRotationApplier |
RasterSharpener | Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
RasterSubsetter | Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter. |
RasterTiler | Splits each input raster into a series of tiles by specifying either a tile size in cells/pixels or the number of tiles. |
RasterToPolygonCoercer | Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster. |
WebMapTiler | Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles. |
Working with Bands
RasterBandAdder | Adds a new band to a raster feature. |
RasterBandCombiner | Merges coincidental raster features into a single output raster feature, preserving and appending all bands. |
RasterBandInterpretationCoercer |
RasterBandKeeper |
RasterBandMinMaxExtractor | Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute. |
RasterBandNameSetter | Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers. |
RasterBandNodataRemover | Removes the existing nodata identifier from selected bands of a raster feature. Any values previously equal to the nodata value are considered valid data. |
RasterBandNodataSetter | Sets a new nodata value on selected bands of a raster feature. |
RasterBandOrderer | Specifies the required order of bands in a raster. Bands are reordered according to the input band indices. |
RasterBandPropertyExtractor | Extracts the band and palette properties of a raster feature and exposes them as attributes. |
RasterBandRemover | Removes any selected bands from a raster feature. |
RasterBandSeparator | Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations. |
RasterStatisticsCalculator | Calculates statistics on raster bands and adds the results as attributes. |
Working with Cells
RasterAspectCalculator |
RasterCellCoercer | Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes. |
RasterCellValueCalculator | Evaluates basic arithmetic , minimum, maximum or average operations on the cell values of a pair of rasters. |
RasterCellValueReplacer | Replaces a range of band values in a raster with a new single value. |
RasterCellValueRounder | Rounds off raster cell values. |
RasterSegmenter | Partitions a raster image into arbitrarily sized groups of cells from the input image based on intensity differences in the input raster image cells. |
RasterSingularCellValueCalculator | Performs basic arithmetic operations on the cell values of a raster against a numeric value. |
RasterSlopeCalculator | Calculates the slope (maximum rate of change in z) for each cell of a raster. |
Working with Palettes
RasterPaletteAdder |
RasterPaletteExtractor | Creates a string representation of an existing palette on a raster and saves it to an attribute. |
RasterPaletteGenerator | Generates a palette out of the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette. |
RasterPaletteInterpretationCoercer |
RasterPaletteNodataSetter |
RasterPaletteRemover | Removes selected palette(s) from raster features. |
RasterPaletteResolver | Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands. |
Workflow Control
RasterCheckpointer | Forces accumulated raster operations to be processed, saving the state to disk and releasing resources to tune performance or assist with memory limitations. |
RasterConsumer | Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features. |
RasterExtractor | Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats. |
RasterNumericCreator | Creates a numeric raster of specified size and resolution, with default cell values. |
RasterReplacer | Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster. |
RasterRGBCreator | Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values. |
RasterSelector |
Vectors and Rasters
ImageRasterizer | Creates a raster representation of vector or point cloud input features, using the fme_color attribute over a solid background fill for vector features. Point clouds may be rendered using their color or intensity components. |
NumericRasterizer | Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background. |
MapnikRasterizer | Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit. |
PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
PointOnRasterValueExtractor | Extracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the feature. |
RasterDEMGenerator | Produces a raster digital elevation model (DEM) by uniformly sampling a Delaunay triangulation generated from input points and breaklines. |
VectorOnRasterOverlayer | Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components. |
Raster features with interpretation type modified and values converted as specified.
INVALID_RASTER_NO_BANDS
Destination Interpretation Type |
Select the destination interpretation along with the bit depth. Different interpretations allow for different conversion options to be used. If any bands on the raster contain palettes, then the destination interpretation is restricted to UInt8, UInt16 or UInt32. |
RGBA to RGB |
Select the action to perform when converting four bands representing an RGBA raster to three bands representing an RGB raster.
RGB to RGBA |
Select the action to perform when converting three bands representing an RGB raster to four bands representing an RGBA raster.
Convert from Color to Color Convert from Numeric to Color Convert from Color to Numeric Convert from Numeric to Numeric |
Select the action to undertake when the given conversion between different types or different bit depths occurs.
* Note: Cast and Bounded Cast use C-style casts. |
Convert from Float to Integer |
Specifies the action to perform when converting from a floating-point value to an integer.
Dialog Options - Tables
Dependencies | None |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History | This transformer replaces the RasterDataTypeCoercer and RasterColorModelCoercer transformers. |
Search for all results about the RasterInterpretationCoercer on the FME Community.
