CoordinateSystemSetter
Assigns a specified coordinate system to features, without modifying geometry or coordinates.
- Adding missing coordinate systems
- Adding coordinate systems when the features’ original format does not support them.
- Fixing incorrect coordinate systems
The CoordinateSystemSetter receives any feature and assigns a specified coordinate system to it. No geometry is modified, and data is not reprojected.
The coordinate system may be entered explicitly or set to an attribute value, user parameter, or conditional value.
If a feature already has a coordinate system assigned, it will be overwritten.
FME inherently supports coordinate system transformations and reprojections, using the CS-Map coordinate system library.
Dialog Options - Tables
Dependencies | None |
FME Licensing Level | FME Base Edition and above |
Aliases | |
History |
Search for all results about the CoordinateSystemSetter on the FME Community.
