PROJAttributeReprojector
Transformation Type
This parameter specifies whether to use an Automatic Transformation or Manual Transformation.
For an Automatic Transformation, a source and destination coordinate system are selected and a transformation is chosen automatically by PROJ. For information on how PROJ performs automatic transformations, see the PROJ documentation - Computation of coordinate operations between two CRS.
For a Manual Transformation, a PROJ string must be provided describing the desired transformation.
Automatic Transformation Parameters
The source and destination coordinate systems can be specified using any format recognized by PROJ such as EPSG numbers (formatted as EPSG:XXXX), WKT1 or WKT2 strings, and PROJ strings (excluding pipelines). FME will attempt to determine what the destination coordinate system’s corresponding FME coordinate system is and will tag the output features with it, unless an override is specified for the Output Coordinate System Tag.
Manual Transformation Parameters
The transformation can be specified using any PROJ string (including PROJ pipelines with multiple steps) that specifies a valid transformation. See the PROJ Documentation for examples.
Note: When reprojecting rasters or point clouds, the transformation specified here must be invertible.
Attributes
Choose which X, Y, and Z attributes to reproject.
Coordinate System Definitions
There are three main methods for defining coordinate systems to be used with the PROJAttributeReprojector. EPSG numbers, WKT1 or WKT2 strings and PROJ strings. They are fully interchangeable and can be used in any combination to define the source and destination coordinate systems of an automatic transformation.
For example, here is LL-WGS84 defined with each method:
EPSG |
EPSG:4326 |
WKT2 |
GEODCRS["WGS 84", DATUM["World Geodetic System 1984", ELLIPSOID["WGS 84",6378137,298.257223563, LENGTHUNIT["metre",1.0]]], CS[ellipsoidal,2], AXIS["latitude",north,ORDER[1]], AXIS["longitude",east,ORDER[2]], ANGLEUNIT["degree",0.01745329252], ID["EPSG",4326]] |
PROJ |
+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs |
- This transformer does not change the feature's coordinates – it only changes the values of the selected X, Y, and Z attributes (if they contain coordinate values).
Most grids needed by PROJ are already included with FME, however additional grid packs from PROJ can also be downloaded from the PROJ website. To use them, download the required proj-datumgrid archive from the above link and extract it to Reproject/ProjData within the FME install folder. PROJ will then automatically detect and use the new grids.
Dialog Options - Tables
Keywords: pointcloud
