CoordinateSystemExtractor
Retrieves the FME coordinate system name of the feature into an attribute.
- Identifying the coordinate system of a feature or dataset.
The CoordinateSystemExtractor receives any type of geometry and retrieves its FME coordinate system name, adding it to the features as an attribute.
If the input feature does not have a coordinate system defined, or if its coordinate system is not present in the FME coordinate systems file coordsys.db, the attribute value will be blank.
In this example, we have a shapefile of transit lines. Note that the FME Data Inspector knows what the coordinate system is and displays it, but that information is not readily accessible in attribute form.
The transit lines are routed into a CoordinateSystemExtractor.
In the parameters dialog, we keep the default Coordinate System Attribute name of _coordsys.
The output features now have the coordinate system name stored as a new attribute.
- To convert the FME coordinate system name to another format such as EPSG number or OGC WKT, use the CoordinateSystemDescriptionConverter.
- To manually assign a coordinate system, use the CoordinateSystemSetter.
- For more information, see Working with Coordinate Systems.
FME inherently supports coordinate system transformations and reprojections, using the CS-Map coordinate system library.
Coordinate System Support
These transformers perform various coordinate system-related tasks, but do not reproject the data. If a coordinate system library is required for a task, CS-Map is used.
Converts coordinate system names and definitions between FME’s internal format and common third-party and open source representations, storing the results as an attribute. |
Retrieves the FME coordinate system name of the feature into an attribute. |
Removes the coordinate system from all input features. |
Tags all features with the local coordinate system defined by the specified parameters. It does not reproject features, or otherwise modify their geometry. |
Different coordinate system libraries (engines) not only contain coordinate system definitions, they also have unique reprojection algorithms. FME’s generic reprojection transformers, in the first table below, use CS-Map. A selection of other libraries is also available, some of which are specific to certain areas of the world or certain software platforms.
Default reprojections, as in a workspace with different input and output coordinate systems selected, are performed with the CS-Map library, also the equivalent of using the generic Reprojector transformer.
If you are reprojecting explicitly with a transformer in the workspace, using library-specific transformers is recommended. In the case of CsmapReprojector versus the Reprojector, the library is identical, but the CSMapReprojector handles vertical coordinate calculations whereas the Reprojector does not.
Library |
Reprojects x,y coordinates stored as attributes from one coordinate system to another. |
CS-Map |
Reprojects a set of features to a local coordinate system with units of meters centered on the bounding box of the features. |
CS-Map |
CS-Map |
Converts a given distance from one coordinate system to another. |
CS-Map |
Reprojects feature coordinates from one coordinate system to another. |
CS-Map |
Library (External Links) |
Reprojects attributes from one coordinate system to another using the CS-MAP library. |
Reprojects feature coordinates from one coordinate system to another using the CS-Map library. |
Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII reprojection library. This library allows you to use the GridInQuestIIReprojector to transform coordinates between ETRS89 (WGS84) and the national coordinate systems of Great Britain, Northern Ireland and the Republic of Ireland. |
Sweden |
Reprojects attributes holding coordinate values from one coordinate system to another using the Gtrans reprojection library (from the National Land Survey of Sweden), and the specified translation file. |
Sweden |
Reprojects features from one coordinate system to another using the Gtrans reprojection library (from the National Land Survey of Sweden) and the specified translation file. |
Reprojects attributes from one coordinate system to another using the PROJ library. |
Switzerland |
Reprojects feature coordinates from one coordinate system to another using the REFRAME library. This transformer handles the usual planimetric and altimetric reference frame change for Switzerland. |
Features with the extracted coordinate system name stored as an attribute.
Coordinate System Attribute |
The name of the attribute to contain the extracted coordinate system name. |
Dialog Options - Tables
Dependencies | None |
FME Licensing Level | FME Base Edition and above |
Aliases | CoordinateSystemFetcher |
History |
Search for all results about the CoordinateSystemExtractor on the FME Community.
