RasterRotationApplier
Rotates a raster feature according to its rotation angle property, interpolating new cell values, updating all other affected raster properties, and producing an output raster feature with a rotation angle of zero.
- Creating rotated rasters compatible with processing, formats, or applications that cannot handle a rotation angle.
The RasterRotationApplier receives raster features with non-zero Rotation values and produces rotated rasters.
Raster features are typically stored in a horizontal alignment, with rotation stored as a property of that raster. All geometric operations include this rotation property in their calculations. This transformer actually rotates the raster feature, according to the value of the rotation property. Cells are moved and their values interpolated accordingly. Raster properties affected by the rotation are all updated and the original rotation property is removed..
The output raster has the same dimensions as the minimum bounding rectangle of the original raster with rotation applied, and new cell values are calculated, with a selection of interpolation methods available.
Areas outside of the original raster’s coverage are filled with nodata (if nodata has been set on the input feature) or zero (0).
The Rotation in Radian CCW value of the output raster is 0,0.
In this example, we will demonstrate the effects of both setting and applying a rotation angle to a raster.
Note that the original raster is not rotated, with a Rotation in Radian CCW property of 0,0.
The raster is first routed into a Rotator.
In the parameters dialog, the Rotation Angle is set to 30 degrees.
A rotation angle of 30 degrees is attached to the raster feature as a property. The FME Data Inspector interprets this new Rotation and displays the raster accordingly, rotating it around the upper left corner. The Rotation Angle has been converted from degrees to radians.
The rotated raster is shown here over the original. The rotation is a result of the display method - the raster itself has not been fundamentally altered, and the rotation could easily be changed or undone.
Note that the individual cells are shown at the rotated angle.
The raster is now routed into a RasterRotationApplier.
In the parameters dialog, Interpolation Type is set to Bilinear.
The output raster contains the rotated raster placed in a new raster, which has the dimensions of the minimum bounding rectangle of the rotated feature.
Cells outside the coverage of the original raster are given the value zero (0) on all bands, showing black. A RasterBandNodataSetter could be used to render them transparently.
The Rotation in Radian CCW of the new output raster feature is 0,0.
The cells have been reinterpreted, using the selected Interpolation Type, and are unrotated.
- A nodata value may be set on the input raster by using a RasterBandNodataSetter prior to the RasterRotationApplier.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
Unrotated raster features with a Rotation in Radian CCW of 0,0, containing an interpolated representation of the rotated input raster feature.
INVALID_RASTER_NO_BANDS
INVALID_RASTER_CANNOT_ROTATE
| Interpolation Type |
Cell values are interpolated in order to produce the unrotated output raster:
| History | |
| Categories |
Search for all results about the RasterRotationApplier on the FME Community.
