RasterNumericCreator
Creates a numeric raster of specified size and resolution, with default cell values.
- Workspace testing
- Creating numeric raster placeholders
The RasterNumericCreator creates a single numeric raster feature, based on specified size, resolution, rotation, and interpretation type. Size may be defined either by number of rows and columns, or by extents.
Minimum and maximum cell values must be provided, and a nodata value may optionally be defined.
The output raster feature may be generated with a choice of patterns, shown here on a 24 by 24 cell raster:
| Single Value | All cells have the Max Numeric Value. |
| Checkered Pattern | One set of cells is set to the Max Numeric Value, and alternating cells have values between the Min and Max Numeric Values. |
| Checkerboard | An 8 by 8 checkerboard pattern is created, with alternating blocks of cells set to the Min and Max Numeric Values. |
In this example, we will create a numeric raster for testing purposes, enabling us to run and test a workspace before the actual data is available. A RasterNumericCreator is added to the workspace, and feature caching (A) allows us to view the raster as it exits the transformer.
In the parameters dialog, we choose Size Specification as RowsColumns, and specify the size as 1600 by 1000 cells.
An Interpretation of Int32 with Min and Max Numeric Values of 0 to 13000 are appropriate for our test scenario, where the output raster will be a placeholder for a raster DEM. 13,000 is the highest expected elevation for the area.
The Data Pattern for the output raster is Checkered Pattern, which will provide a range of cell values to test against.
The output raster feature has the specified size, and one INT32 band. It is passed along to the next transformer and can now be used in the workspace.
Zooming in closely, the alternating cell values can be seen.
- To create an RGB raster in a similar manner, use the RasterRGBCreator.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
This transformer has no input ports.
One numeric raster feature, according to the specified parameters.
| Size Specification |
Select the type of size specification: RowsColumns: Set dimensions by number of rows and columns. Extents: Size based on extents and cell spacing. Corner coordinates (upper left and lower right) define extents. |
Number of Columns (cells) Number of Rows (cells) |
When Size Specification is RowsColumns, specify the number of rows and columns for the output raster. The minimum value for both rows and columns is one (1). |
X Cell Origin Y Cell Origin |
Specify the origin for each cell. This can be used to specify whether each cell's data point is at the lower-left or center (or somewhere else) within the cell. |
X Cell Spacing Y Cell Spacing |
Specify the spacing between cell elements, that is, the width and height of an individual cell. This must be greater than zero. |
X Upper Left Coordinate Y Upper Left Coordinate |
Specify the coordinates of the upper left corner of the raster. Default is 0,0. |
X Lower Right Coordinate Y Lower Right Coordinate |
When Size Specification is Extents, specify the coordinates of the lower right corner. |
| Rotation | Specify the rotation of the raster. Default is 0.0. |
Interpretation |
Select an Interpretation Type for the output raster. Choices include:
Min. Numeric Value Max. Numeric Value |
Specify the range of cell values to be used for generating the selected Data Pattern. |
Nodata Numeric Value |
Optional: Set a Nodata Value on the output raster. |
Data Pattern |
Select a pattern for the output raster: Single Value: All cells are set to the Max Numeric Value, producing a solid image. Checkered Pattern: Alternating cells have values between the Min and Max Numeric Values. Checkerboard: An 8 by 8 checkerboard pattern is created, with alternating blocks of cells set to the Min and Max Numeric Values. The size of the blocks is variable, and dependent on the number of rows and columns specified. If the number of rows and columns are not multiples of eight, the remaining data will be set to either nodata values or the minimum value. |
Not Applicable |
Not Applicable |
| History | |
| Categories |
Search for all results about the RasterNumericCreator on the FME Community.
