RasterPaletteGenerator
Generates a palette from the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette.
- Creating a palette based on raster contents for use elsewhere.
- Reducing file size or bit depth on rasters to meet format or processing requirements.
The RasterPaletteGenerator receives raster features and builds a palette from the existing cell values. The output raster feature will have the selected band(s) replaced with a band with the resulting palette, and cell values replaced with palette key values.
The Palette Key Interpretation Type may be UInt8, UInt16, or UInt32, and both the new palette and band will have the chosen interpretation type. The number of palette keys generated can be automatically determined, or specified within the range of 16 to the maximum number of values supported by the interpretation type.
Key Interpretation Type |
Key Value Range |
Minimum Number of Keys |
Maximum Number of Keys |
| UInt8 | 0 to 255 | 16 | 256 |
| UInt16 | 0 to 65,535 | 16 | 65,536 |
| UInt32 | 0 to 4,294,967,295 | 16 | 4,294,967,296 |
Valid palette types that may be produced include:
- RGB24
- RGB48
- RGBA32
- RGBA64
- GRAY8
- GRAY16
This operation may cause loss of precision if the maximum number of palette entries is less than the number of unique band values. In this case, the data values in the palette may not capture all the original band data values.
This transformer supports raster band selection. The RasterSelector can be used to modify selection.
In this example, we start with an orthoimage raster. It has three bands - red, green, and blue - and we will generate a single band with a palette from those colors.
The raster is routed into a RasterPaletteGenerator.
In the parameters dialog, Palette Key Interpretation Type is set to UInt8 (unsigned 8-bit integer).
UInt8 has a possible range of values of 0 to 255, and we could generate a total of 256 palette keys and color values. However, we will set the Maximum Number of Palette Entries to 16, producing the smallest palette possible.
The output raster has one band, with a palette of 16 keys and associated RGB values. Note that band name of the first band (Red) has been carried forward - that could be removed with a RasterBandNameSetter if desired.
The range of colors in the original raster was not widely varied, and so this output raster looks very much like the original. If the input raster had a wider range of colors, a 16 item palette would introduce more generalization (and loss) of colors.
- To extract a generated palette as a string to write to a file or use elsewhere, use a RasterPaletteExtractor after the RasterPaletteGenerator.
- To add an existing palette to raster, use the RasterPaletteAdder.
- To replace cell values with values from an existing palette, use the RasterPaletteResolver.
- The input raster feature must have the correct number of bands selected, in the correct order, and of the correct interpretation type. The RasterSelector, RasterBandOrderer and RasterBandInterpretationCoercer may be used if necessary, prior to the RasterPaletteGenerator, to meet these requirements.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
This transformer accepts only raster features. Selected band(s) must not have existing palettes.
Raster features with the selected band(s) replaced by a single band and palette according to parameter selections.
INVALID_RASTER_BAND
| Palette Key Interpretation Type |
Select the interpretation type for the generated palette keys. Choices include:
| Maximum Number of Palette Entries (Optional) |
Optionally, specify the maximum number of palette entries (key and value pairs) to be generated. If blank, the number of entries will be equal to the maximum number available according to the Palette Key Interpretation Type. |
| History | |
| Categories |
Search for all results about the RasterPaletteGenerator on the FME Community.
