RasterGCPSetter
Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates.
- Specifying georeferencing information for rasters such as scanned maps, surveys, and uncorrected aerial images, based on known positions in the source dataset.
The RasterGCPSetter receives raster features and attaches specified Ground Control Points (GCPs) to them as a raster property.
Each GCP is composed of a pair of positions - the first being a row and column number within the raster, and the second being a known position on the ground, described by a Coordinate System and a set of x,y,z coordinates.
Multiple GCPs may be set with one RasterGCPSetter, and must all be the same coordinate system.
The RasterGCPSetter does not georeference rasters - it only attaches properties that may be used to do so. The GCPs must be applied to the raster to carry out the georeferencing.
A minimum of three GCPs are generally required to georeference a raster. If the raster has already set GCPs, the old GCPs will be overwritten, and so all GCPs must be set in one RasterGCPSetter.
GCP Format
Each GCP has five components, separated by spaces:
Column Row X-Coordinate Y-Coordinate Z-Coordinate
For example:
1442 6863 483000 5456000 0
Multiple GCPs are combined into one string, separated by semicolons:
1442 6863 483000 5456000 0;1415 1143 483000 5468000 0;4754 1120 490000 5468000 0
In this example, we will add Ground Control Points to a scanned map. The original raster is a complete topographical map with grid lines showing northings and eastings.
Note that the raster’s coordinate system is not known - it is not currently georeferenced.
We want at least three GCPs to position the image, and we will identify those prior to configuring the workspace. The coordinate system is UTM27-10, as indicated on the map’s title block.
The first GCP is near the bottom left of the map, where two labeled grid lines intersect. Note that we can identify the cell position (row and column), where the northing and easting intersect.
The first GCP will pair the cell (1442, 6863) with the x,y,z coordinates (483000, 5456000,0). For the purposes of this exercise z is not important, and so is set to zero (0).
The same process is used to identify GCPs near the upper left and upper right corners of the map. Units are in meters, per the coordinate system identified.
GCP |
Cell x (Column) |
Cell y (Row) |
X-Coordinate (Easting) |
Y-Coordinate (Northing) |
Z-Coordinate |
Lower left |
1442 |
6863 |
483000 |
5456000 |
0 |
Upper left |
1415 |
1143 |
483000 |
5468000 |
0 |
Upper right |
4754 |
1120 |
490000 |
5468000 |
0 |
The raster is routed into a RasterGCPSetter.
In the parameters dialog, Source Coordinate System is set to UTM27-10.
The GCP Value parameter receives a string containing all of the identified GCPs. Each GCP is composed of five values, separated by spaces:
The individual GCPs are separated from each other by semicolons, producing this complete string:
The output raster now has the GCPs stored as a property. However, they have not yet been applied to the raster to georeference it.
GCPs can be applied to the raster in appropriate raster format Readers, or in third-party tools that recognize GCPs.
Alternatively, to apply our GCPs, we will use a RasterGCPApplier transformer from the FME Hub.
This transformer has no parameters to configure.
The output raster is georeferenced, with a Coordinate System of UTM27-10 and Extents that reflect valid ground coordinates. It is shown here in the FME Data Inspector with a current streets shapefile overlaid in yellow for context.
Note that the Rotation and Affine Transform values are altered, which indicates the transformations caused by applying the GCPs, and that the GCPs have been removed from the raster properties.
- To apply GCPs to a raster in FME, you may use the Apply GCPs parameter in raster format Readers that support GCPs. A RasterGCPApplier custom transformer is also available on the FME Hub.
- To extract GCP values from a raster, use the RasterGCPExtractor.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
Raster features with GCPs stored as raster properties, as specified in the parameters dialog.
| Source Coordinate System |
Select the coordinate system that would be effective if the Ground Control Points were applied to the raster. This is not necessarily equivalent to the coordinate system of the raster feature. |
| GCP Value |
A string value specifying the GCPs. Each GCP has five components, separated by spaces: Column Row X-Coordinate Y-Coordinate Z-Coordinate For example: 1442 6863 483000 5456000 0 Multiple GCPs are combined into one string, separated by semicolons: 1442 6863 483000 5456000 0;1415 1143 483000 5468000 0;4754 1120 490000 5468000 0 |
| History | |
| Categories |
Search for all results about the RasterGCPSetter on the FME Community.
Contains information licensed under the Open Government Licence – Canada.
