Accesses ProjectWise through a Bentley Web Services Gateway (WSG). A WSG is a server-side application that opens a communication channel between an app, in this case FME and the ProjectWiseWSGConnector, and Bentley's project information management system, which in this case is ProjectWise.
A WSG is comprised of two main components. The first component is the WSG framework which uses a REST web services API to communicate with apps to authenticate, send data, and receive data. The second component is a set of providers that communicate directly with individual management systems. The provider of interest to the ProjectWiseWSGConnector is the ProjectWise provider, which allows access to ProjectWise data sources.
The ProjectWiseWSGConnector uses your ProjectWise account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the ProjectWise service.
Depending on your choice of actions, it will upload files, folders, and attributes; download documents and projects; list information of objects; or delete objects from the service.
In this example, the ProjectWiseWSGConnector is used to download a Bentley MicroStation Design document from ProjectWise. We start by creating a valid web connection to a WSG deployment (which can be done right in the ProjectWise Account parameter) and browsing to the Design document, which retrieves the Object ID for the document. Finally, we choose to download as a File and select a destination for the download.
A FeatureReader is added to read the newly downloaded dataset. Here, the A-H1-G-Pave feature type will be further processed elsewhere in the workspace.
By executing the download here in the workspace, the Design document will be refreshed every time the workspace is run.
In this example, the ProjectWiseWSGConnector is used to download a raster from ProjectWise into an attribute.
The document is read from ProjectWise and the contents stored as a blob attribute. Then a RasterReplacer is used to interpret the blob into a usable raster format.
The combination of these two transformers avoids having to download the image to local storage and re-read it. A similar technique can be used for point cloud files, using the PointCloudReplacer transformer.
The output of this transformer will vary depending on the ProjectWise Action performed.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the ProjectWiseWSGConnector already having a value for fme_rejection_code, this value will be removed.
ProjectWise Action |
The type of operation to perform. Choices include:
ProjectWise Account |
Performing operations on ProjectWise through a Bentley Web Service Gateway requires the use of a basic authentication using a Web Connection. To create a ProjectWise connection, click the 'ProjectWise Account' drop-down box and select 'Add Web Connection...'. The connection parameters are:
The connection can then be managed via Tools -> FME Options... -> Web Connections. |
The remaining parameters available depend on the value of the Request > ProjectWise Action parameter. Parameters for each ProjectWise Action are detailed below.
Object ID |
The Object ID of a document or project on ProjectWise to delete. If valid credentials have been provided as a web connection, you may browse to a location. |
Object ID |
The Object ID of the document/project to download. If valid credentials have been provided as a web connection, you may browse to a location. |
Download as |
Select whether to store the downloaded data in a File, Folder or Attribute.
Download to Folder | Specify the path to the folder that will store the downloaded document. Valid for Download as File or Folder. |
Include Subfolders | Choose whether to download subprojects of the ProjectWise Source or not. Valid for Download as Folder only. |
Download to Attribute |
Specify the attribute that will store the contents of the downloaded document. Valid for Download as Attribute only. Note: FME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as File instead. |
ProjectWise Object ID |
The Object ID to list the contents of. If valid credentials have been provided as a web connection, you may browse to a location. |
Default attribute names are provided, and may be overwritten.
Class Name |
Specify the attribute to hold the name of an object on ProjectWise. |
Instance ID |
Specify the attribute to hold the instance ID of an object on ProjectWise. |
Object ID |
Specify the attribute to hold the object ID of an object on ProjectWise. |
Class Type |
Specify the attribute to hold the type of an object on ProjectWise. |
Description |
Specify the attribute to hold the description of an object on ProjectWise. |
Create Time |
Specify the attribute to hold the creation time of an object on ProjectWise. |
Update Time |
Specify the attribute to hold the last updated time of an object on ProjectWise. |
Relative Path |
Specify the attribute to hold the relative path to an object on ProjectWise. |
Document Name |
Specify the attribute to hold the document name of a document on ProjectWise. Only added for document type objects. |
Document Size |
Specify the attribute to hold the size of a document on ProjectWise. Only added for document type objects. |
Document Last Modified |
Specify the attribute to hold the last modified time of a document on ProjectWise. Only added for document type objects. |
Document MIME Type |
Specify the attribute to hold the MIME type of a document on ProjectWise. Only added for document type objects. |
Upload |
The type of data to be uploaded.
When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. ProjectWise will not overwrite documents of the same name. If trying to upload a file with the same name as an existing document, the existing document’s ID will be returned. When wanting to upload content from a folder, it is better to upload as a folder instead of setting a fixed path and sending multiple features into the connector to upload as a file. |
File to Upload |
The file to be uploaded to ProjectWise if Upload is set to File. |
Folder to Upload |
The folder to be uploaded to ProjectWise if Upload is set to Folder. |
Choose whether to upload subfolders of the Folder to Upload or not. |
Attribute to Upload as File |
The data to be uploaded, supplied from an attribute if Upload is set to Attribute. |
Project Object ID | The Object ID of the project to upload the data to. If valid credentials have been provided as a web connection, you may browse to a location. |
Upload with File Name | The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc). |
Instance ID |
Specify the output attribute that will store the instance ID of the file/folder that was just uploaded. |
Object ID | Specify the output attribute that will store the object ID of the file/folder that was just uploaded. |
A set of control characters is available in the Text Editor. | |
Working with User Parameters | Create your own editable parameters. |
Dependencies | Bentley ProjectWise CONNECT Edition, Bentley Web Services Gateway, Bentley WSG ProjectWise Plugin |
FME Licensing Level | FME Base Edition and above |
Aliases | |
History | Released FME 2018.0 |
Categories |
Search for all results about the ProjectWiseWSGConnector on the FME Community.
