The point cloud format used to decode the blob.
The attribute from which the blob will be read.
Note that this transformer only works with point cloud formats. Use the GeometryReplacer for vector formats or the RasterReplacer for raster formats.
Currently supported formats include:
This transformer is typically used to restore a point cloud previously extracted into an attribute by the PointCloudExtractor.
FME Factory Used: @GeometryFormat
Keywords: geometry database extract replace blob serialize
